Installing A Grounding Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 08:48 PM   #1
Installing a grounding rod
Looking at installing a grounding rod for my home. Let's pretend I know nothing about anything and go from there.
Currently, my home is being grounded through my cold water pipe. I believe it would be wise to sink a rod outside for more safety.
Advantages of rod vs. cold water pipe by the way? My home is built on a slab, and I suspect my grounding wires to the cold water pipe are in concrete... If that matters?
Cm1384 is offline   Reply With Quote
Old 03-24-2011, 09:13 PM   #2
I=E/R
a7ecorsair's Avatar
Just curious. What do you think is the advantage of adding another grounding electrode / ground rod?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Speedy Petey (03-25-2011)
Old 03-24-2011, 09:13 PM   #3
Rewards Points: 506
You suspect that you have a Ufer?
jlmran is offline   Reply With Quote
Old 03-24-2011, 09:19 PM   #4
I don't think I do, after researching what it was. It appears to just ground at my cold water pipe.
Old 03-24-2011, 10:05 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
then drive a rod. Depending on how much wire you need, you should be able to do it for ~$50. It won't hurt to drive one.
Old 03-24-2011, 11:44 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Drive a rod it is actually a current code requirement to have a supplemental grounding electrode to the metal water pipe.
Understand that the grounding electrode system (GES) is for property protection from lightning, power surges and those types of events.
It is not considered a protection for humans from electrocution.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-25-2011, 07:09 AM   #7
Rewards Points: 154
your grounding electrode or ground rod is there to prevent open neutrals, thats it nothing else
the transformer is centre tapped and grounded, if you lose this ground and you didnt have your grounding electrode or ground rod you would only have 240 at your house not 120/240
awdblazer is offline   Reply With Quote
Old 03-25-2011, 07:28 AM   #8
I=E/R
a7ecorsair's Avatar
Your reply is incorrect.
Old 03-25-2011, 08:32 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Completely and utterly incorrect.
Wow!
Old 03-25-2011, 08:35 AM   #10
A grounding electrode has absolutely nothing to do with the day to day workings of an electrical system, NOR is it any form of "backup" or safety ground for the system.
Old 03-25-2011, 09:20 AM   #11
If it's not day to day, not backup, and not safety, then what is it for?
pyper is offline   Reply With Quote
Old 03-25-2011, 09:58 AM   #12
I=E/R
a7ecorsair's Avatar
Lightning strikes
pyper (03-25-2011)
Old 03-25-2011, 10:01 AM   #13
Electrician
SD515's Avatar
Rewards Points: 504
See Stubbie's post #6
Kyle
Old 03-25-2011, 10:18 AM   #14
Lightning strikes
Seems like that's a safety issue
Old 03-25-2011, 10:26 AM   #15
I=E/R
a7ecorsair's Avatar
referring to the previous suggestion that its purpose was to provide an neutral path backup.
pyper (03-25-2011)
grounding electrode conductor question bsperr Electrical 8 12-05-2009 09:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
