Installing Ground Screw On Homelite Fuse Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 06:50 AM   #1
Installing ground screw on Homelite fuse panel
I was wondering does anyone know exactly where I should mount the ground screw on a 100 amp Homelite fuse panel? Usually there is a place on the ground terminal where this screw goes but on this panel there isn't one. Should I just screw it on the neutral or ground terminal block itself where the neutral and ground wires go?
mellemel1969 is offline   Reply With Quote
Old 10-23-2013, 08:05 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 664
Moved to electrical
Old 10-23-2013, 08:12 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
We would need to see a picture and clarification on if you are mounting a ground bar or a bond screw/jumper.
The Following User Says Thank You to k_buz For This Useful Post:
plummen (10-23-2013)
Old 10-23-2013, 09:46 AM   #4
Master Electrician
Rewards Points: 3,866
Homelite or Homeline??? Usually a Homeline bonding screw goes in the middle of the buss connecting bar. Have you read the instructions?
http://www.schneider-electric.us/sit...&redirect=true
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 10-23-2013, 10:08 AM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If it looks like this, it'll go here
Installing ground screw on Homelite fuse panel-square-d-homeline-service-panel-pic.jpg
wirenut1110 is offline   Reply With Quote
The Following 2 Users Say Thank You to wirenut1110 For This Useful Post:
brric (10-23-2013), Philly Master (10-23-2013)
Old 10-23-2013, 11:59 AM   #6
k_buz's Avatar
We don't know if it is a sub or main panel...makes a BIG difference,
The Following 2 Users Say Thank You to k_buz For This Useful Post:
gregzoll (10-23-2013), Know A Little (10-23-2013)
Old 10-23-2013, 04:15 PM   #7
Rewards Points: 3,130
Ground screw? Homelite? Fuse panel? Ground terminal? Too much incorrect terminology to give me any confidence you know what you're doing. Would help to know why you're asking about this.
If it's the green BONDING SCREW you're talking about, the picture posted above is right on - looks just like my Homeline panel. But that screw is used only in the main panel, not any subpanel. If you're referring to the GROUND BAR, Homeline panels (at least all I've seen) don't come with one - you have to purchase it separately. It comes with its own hardware for attachment to the panel.
The Following User Says Thank You to md2lgyk For This Useful Post:
Speedy Petey (10-23-2013)
Old 10-23-2013, 05:02 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,346
So the question is -
Is it a sub panel or a main panel ?
And yes it matters !
A lot !
dmxtothemax is offline   Reply With Quote
Old 10-23-2013, 07:17 PM   #9
Sorry guys, it is a Homeline. It is the green bonding screw. It is a main panel. I understand that a subpanel doesnt require a bonding screw. Im clear on where it goes now. Some'm panels are different and I just wasn't sure. Thanks guys
Old 10-23-2013, 07:46 PM   #10
Licensed electrician
Rewards Points: 1,608
The locations of the bond screw or strap is clearly labeled on the label.
Old 10-24-2013, 01:12 PM   #11
Glad you got it sorted out. Hope you don't think my previous post was too harsh. Reading posts in Electrical from folks who don't seem to know what they're doing make me cringe. Bad plumbing will get you wet; bad wiring will get you killed.
Replacing an old electrical panel (w/out ground bar) yilmazma Electrical 5 12-13-2012 10:58 AM
Square D Homelite Main Panel - Ground / Neutral Bonding erm1981 Electrical 25 07-17-2012 10:25 PM
Electrical Panel - Ground Bar/Wiring and Safety cfreak Electrical 31 09-11-2011 08:10 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
