-   -   Installing ground screw on Homelite fuse panel (http://www.diychatroom.com/f18/installing-ground-screw-homelite-fuse-panel-189092/)
mellemel1969 10-23-2013 06:50 AM
I was wondering does anyone know exactly where I should mount the ground screw on a 100 amp Homelite fuse panel? Usually there is a place on the ground terminal where this screw goes but on this panel there isn't one. Should I just screw it on the neutral or ground terminal block itself where the neutral and ground wires go?
TheEplumber 10-23-2013 08:05 AM
199 Attachment(s)
Moved to electrical
k_buz 10-23-2013 08:12 AM
We would need to see a picture and clarification on if you are mounting a ground bar or a bond screw/jumper.
brric 10-23-2013 09:46 AM
Homelite or Homeline??? Usually a Homeline bonding screw goes in the middle of the buss connecting bar. Have you read the instructions?
http://www.schneider-electric.us/sit...&redirect=true
wirenut1110 10-23-2013 10:08 AM
1 Attachment(s)
If it looks like this, it'll go here
k_buz 10-23-2013 11:59 AM
We don't know if it is a sub or main panel...makes a BIG difference,
md2lgyk 10-23-2013 04:15 PM
Ground screw? Homelite? Fuse panel? Ground terminal? Too much incorrect terminology to give me any confidence you know what you're doing. Would help to know why you're asking about this.
If it's the green BONDING SCREW you're talking about, the picture posted above is right on - looks just like my Homeline panel. But that screw is used only in the main panel, not any subpanel. If you're referring to the GROUND BAR, Homeline panels (at least all I've seen) don't come with one - you have to purchase it separately. It comes with its own hardware for attachment to the panel.
dmxtothemax 10-23-2013 05:02 PM
So the question is -
Is it a sub panel or a main panel ?
And yes it matters !
A lot !
mellemel1969 10-23-2013 07:17 PM
Sorry guys, it is a Homeline. It is the green bonding screw. It is a main panel. I understand that a subpanel doesnt require a bonding screw. Im clear on where it goes now. Some'm panels are different and I just wasn't sure. Thanks guys
Jim Port 10-23-2013 07:46 PM
The locations of the bond screw or strap is clearly labeled on the label.
md2lgyk 10-24-2013 01:12 PM
Glad you got it sorted out. Hope you don't think my previous post was too harsh. Reading posts in Electrical from folks who don't seem to know what they're doing make me cringe. Bad plumbing will get you wet; bad wiring will get you killed.
