Old 12-07-2006, 06:02 AM   #1
Installing GFI problem
Dear Expert Members,
I am instaling a GFI outlet in the bathroom of a old home. The wire from a dedicated bathroom run to the breaker is testing out with a charge on all three wires white, black and ground. At the pannel the black is attached to the breaker and the white and bare ground are attached to the neutral bar. I was under the impression that only one wire, the black, should test out as hot. Can anyone advise me on what the challenge may be?
Thank you
Franko
franko is offline   Reply With Quote
Old 12-07-2006, 06:55 AM   #2
World famous jerk.
Picking up the phone book.
mdshunk is offline   Reply With Quote
Old 12-07-2006, 11:32 AM   #3
I was told there are "ghost voltage" on neutral/ground before... and it is normal... I mean as long as the voltage is real low like < 10volt...
KUIPORNG is offline   Reply With Quote
Old 12-07-2006, 03:57 PM   #4
franko,
I am optimistic that what you are seeing is exactly as KUI****G described, a "ghost voltage" on the long neutral/ground runs. To a neon test lamp or sensitive voltmeter this leakage current will appear as a voltage. Actually, it is leakage current as a result of capacitive coupling of the neutral and ground wires to the line wire. This current is so small that it is completely harmless and consumes no power.
You may wish to prove that it is a "ghost voltage" and not a short, here is how: Make a tester out of a 4W or 7W incandescent night light to use in place of your neon tester. This will completely suppress the "ghost voltage" and the lamp should only light on the black wire.
When installing the GFI outlet, take the time to read all the instructions, they are quite good and necessary.
...Christopher
Christopher is offline   Reply With Quote
Problem installing entry door Jemo Building & Construction 13 11-14-2010 12:31 PM
Problem Installing Toto Aquia on Closet Flange on Floor herbolaryo Plumbing 5 07-20-2007 09:32 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
