Installing Gfi On Outside Of Foundation - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 10:56 AM   #1
Rewards Points: 16
installing gfi on outside of foundation
i want to install a weater tight gfi outlet box on the outside of my foundation
i am installing a new 20amp single pole gfci breaker inside running the wire about 30 feet from breaker box drilling hole through my foundation to run wire through it right into outside outlet box what type of wire shoud i use?Thanks
Bill
ggnuncleb is offline   Reply With Quote
Old 03-07-2012, 11:02 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
12/2 romex.
You do not have to have a gfci receptacle if you are using a breaker.
Make sure you use a tamper resistant, weather proof receptacle with an in-use cover.
I always sleeve my wire with PVC when going through the foundation, but it is not required.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
ggnuncleb (03-07-2012)
Old 03-07-2012, 02:35 PM   #3
Julius793's Avatar
Originally Posted by jbfan
12/2 romex.
Why tamper resistant?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-07-2012, 03:16 PM   #4
It is code depending on what code cycle.
M Engineer is offline   Reply With Quote
Old 03-07-2012, 03:53 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I would use a GFCI receptacle instead of a GFCI breaker, a lot cheaper.
Coastal South Carolina
Old 03-07-2012, 03:57 PM   #6
seansy59's Avatar
Rewards Points: 258
Easier too incase something accidently trips the GFCI. Instead of running inside to reset, just walk over to the outlet instead.
seansy59 is offline   Reply With Quote
Installing wonderboard on pier and beam foundation Harrington Flooring 3 12-01-2010 12:29 PM
installing PVC pilings in water as foundation for a house Mariapanama Building & Construction 2 10-04-2010 10:13 AM
Foundation Drainage bhry Building & Construction 3 09-23-2010 10:08 AM
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
Foundation Work - Installing a walk up stairs handy man88 Building & Construction 2 10-01-2007 12:19 PM
