Old 04-27-2011, 12:18 PM   #1
Installing GFI outlets
I am putting in new outlets for a kitchen (No GFI breakers), IF I put a GFI outlet first in line, will the outlets behind it then be covered as GFI from that first outlet? (first outlet is closest to breaker box)
tsperry is offline   Reply With Quote
Old 04-27-2011, 12:25 PM   #2
Electrical Contractor
Yes, if you wire them correctly.
From the panel, the wire goes to the line side, and the downstream receptacles are fed from the load side of the gfci.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
GFCI Outlets in Series allbymyself Electrical 6 01-25-2011 12:52 AM
Outlets not working mackelroy Electrical 19 01-17-2011 11:22 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 07:19 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 08:28 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
