Installing A GFCI Outlet In An Old Work Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 03:03 PM   #1
Installing a GFCI outlet in an old work box
Hi everyone,
I have an old work box outlet that I need to install a GFCI outlet. The outlet fits, but looks kind of too tight. I have enclosed a picture of the box. Should I wire it from the back? Is it allowed? Will it work? Has it been done before? Thanks
helpless handyman is offline   Reply With Quote
Old 08-30-2010, 03:13 PM   #2
Licensed electrician
Rewards Points: 1,034
It can be done, but you will probably have better luck with a deeper box. Do not bring the cable into the back of the box. Use the knockouts at the back edge of the box.
Old 08-30-2010, 03:24 PM   #3
Hi Jim, and Thanks. The outlet will fit, but I think the screws will be too close to the side of the box. Have you ever installed a GFCI in one of these boxes?
Old 08-30-2010, 03:42 PM   #4
On the GFI's I use the screw seem to be slightly recessed into the body. The metal boxes are a standard width. You should be ok. Remember to ground the box also.
Old 08-30-2010, 03:52 PM   #5
Thanks Jim
Old 08-30-2010, 04:03 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would get a bigger (deeper) box. If you have more than 1 cable coming into that box you ar probably exceeding the fill requirement.
Coastal South Carolina
Old 08-30-2010, 04:10 PM   #7
Only one cable coming inside the box, it's a dedicated circuit.
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 12:08 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 02:53 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
