Installing GE SunSmart 3-Way Digital Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 03:36 PM   #1
Having trouble with installing the GE SunSmart Digital Timer on a 3-way switch for a set of light in my kitchen. In the Kitchen I have 5 switches for 5 different rows of lights in the kitchen. In the Dining Room there is 3 switches of which one of the switches turns on and off one if the row of lights in kitchen. I installed the timer to the switch in the Dining Room which is connected to the lights in the Kitchen. I can turn on and off the lights in the kitchen using the switch in the Dining Room. In the Kitchen I can turn the lights off only with the switch. If I try to turn on the lights in the Kitchen using the switch in the Kitchen, the lights do not come on. Why?
In the dining room, I connected the the red line on the timer to the red line in the outlet, the blue line on the timer to a black line in the outlet and the black line on the timer to the black line in the outlet, white line on the timer to white in the outlet. The green line on the timer, I have not connected to any line.
Sonni is offline   Reply With Quote
Old 04-07-2013, 04:07 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Did you wire it correctly?
Old 04-07-2013, 10:23 PM   #3
Rewards Points: 512
In the Kitchen, I have 5 switches for 5 different rows of lights in the kitchen.
In the Dining Room, there are 3 switches, one
of which turns on and off one row of lights in kitchen.
[fed from?] the lights in the Kitchen.
In the Kitchen, I can only turn the lights off with the switch. If I try to turn the lights in the Kitchen
on, using the switch in the Kitchen, the lights do not come on. Why?
In the dining room, I connected the red line on the timer to the red line in the outlet, the blue line on the timer to a black line in the outlet, the black line on the timer to the black line in the outlet, [and the] white line on the timer to white in the outlet. The green line on the timer is not connected to any line.
FYP, whew
GE sunsmart digital timer to 3 way circuit. Help! rsa130 Electrical 7 07-15-2012 06:43 PM
Digital Timer on GFCI circuit TheRydad Electrical 3 05-20-2012 04:17 PM
Having trouble installing a digital timer nefine Electrical 5 01-13-2012 12:42 AM
installing a GE DIGITAL TIMER Grandbenz Electrical 4 10-23-2011 08:47 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
