I'm attempting to install a new fluorescent light fixture in my garage using the wiring from the current incandescent(?) fixture. The balast on the new fluorescent fixture has two wires coming out of it white and black. The problem I'm running into is that the current fixture has a lot more wires than expected. I've attached 3 pictures of the fixture box. It's hard to see, so here's a quick explanation.
There are two sets of wires(I'm assuming for two light switches) coming into the box on each side. Each set has a 3-wire group with black casing and a 4-wire group with gray casing. For organizations sake, I'll refer to each set as coming into the box from the left or right. The connections are:
Left 3 Wire(Black Casing):
Black wire connected to black wire on Right 3 wire(Black casing)
White wire connected to white wire on Right 3 wire(Black casing).This set was also connected to the light fixture.
Bare wire connected to all other bare wires coming from other sets
Left 4 Wire(Gray Casing):
Black wire connected to black wire on Right 4 wire(Gray casing)
Red wire connected to red wire on Right 4 wire(Gray casing)
White wire connected directly to light fixture.
Right 3 Wire(Black Casing):
Black wire connected to black wire on Left 3 wire(Black casing)
White wire connected to white wire on Left 3 wire(Black casing).This set was also connected to the light fixture.
Right 4 Wire(Gray Casing):
Black wire connected to black wire on Left 4 wire(Gray casing)
Red wire connected to red wire on Left 4 wire(Gray casing)
White wire connected to both black wires from the Left and Right 3 wire (Black Casing)set.
Right 3 wire white should connect to the white on the fixture.
left 4-wire white should connect to black on the fixture.
The 3-way wiring system should be rewired with the red and white used as travelers so the black would feed power to and from the common terminals on the switches. It would simplify life for anyone dealing with it later.
I'm not sure if you're trying to insult me, but that's kind of ludicrous considering this is a DIY forum...of course I don't know what I'm doing. I bought this house two years ago and I'm attempting to fix ALL of the mistakes the original builder/electrician made.
If you don't have anything useful to post, don't post!
If it wasn't intended as an insult to me, please ignore my rant and further explain your comment.
Looks like you wiring was messed up from day 1. There should not be 2 whites hooked to the fixture. White can carry power to a switch but cannot carry a switched hot back to the fixture.
It used to be acceptacle not to re-identify the white as a current carrying conductor, but is not anymore.
For all of you telling me to take notes...take notes on WHAT??? I took the light fixture off and it looked exactly like what you see in the picture. I DID NOT INSTALL this. I unscrewed two screws and this is what I got.
Quit turning this forum into some immature teenage chat room.
Is it just me or did he take what looks to be pretty good notes? Did you guys read the original post? He tells you what came from where, what 3 wires were attached to the fixture, and what he's not even touched.
Thank you for making this comment. Unlike some arrogant electricians (that can't provide any insight), you read my post thoroughly and comprehended my issue.:thumbsup:
Thank you again for your assistance (and patience). Just a quick note, both of the white wires were connected to two screws directly on the light fixture. There were no wires coming out of the light fixture. This wiring/light fixture was part of the original house build in 1984. That may have something to do with it.
I understand, and maybe i'm a little overboard, its just lately the posts of flowing with stuff that people take apart with out paying attention, and maybe its just a little frustrating... but like my original post, it was just a question.
Come on guys. can't you see the kids made there peace and are playing nicely now.
The fire is out and pouring gas on it won't do anything now.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
