Installing Fan With 1/2 Hot Or Remote? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2008, 08:50 PM   #1
Installing fan with 1/2 hot or remote?
I want to add a ceiling fan to our daughters room,The only switch is on the wall is a half hot,I have a chair rail at switch height and completely wallpapered is there a way to fish a wire and use the 1/2 hot switch? or can I use the stacked double switch for power to the fan ( I dont feel like removing the rail and taking a chance of screwing up the wall paper by adding in a double cut in box).
What I really would like to do is just splice into the light in the attic (with a junction box of course)for power and use a remote for on and off,but not sure if that is acceptable? any help would be greatly appreciated.
zombie911 is offline   Reply With Quote
Old 08-22-2008, 10:03 PM   #2
I think you should do that. A ceiling fan draws a very small load even with a light kit, you should be fine tapping off the nearest circuit. Although, most places these days require ALL openings in bedrooms to be arc fault protected. So you might want to check if your house has arc fault circuits in the bedrooms, (look in your panel for arc fault breakers) if so, check and make sure that attic light is being fed from a bedroom circuit. If not then perhaps you can tap off a closet light or something else that is arc faulted.
Super33 is offline   Reply With Quote
Old 08-22-2008, 10:13 PM   #3
Super33,
thanks for the reply.. this is a newer 2 story home with arc faults, so I will look for those cicuts.
Old 08-22-2008, 11:01 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Maybe this is a silly question, what is a '1/2 hot switch' ??
Old 08-22-2008, 11:27 PM   #5
I was thinking it switched half of one or all of the outlets in the room but I could be wrong..
Old 08-23-2008, 11:50 AM   #6
Rewards Points: 126
If you use a remote you do not need the switch. The fan itself has the disconnecting means by the pull chains. Use the nearest lighting circuit available.
Note: It is very important that you know the power is disconnected before you wire up the fan. It would not be good if the fan started to turn while you are on the ladder.
Old 08-23-2008, 11:59 AM   #7
Thanks for the responce...lets asume I wanted it switched if I had 2 sets of wire's coming into the switch box could I add a two in one switch?(I cant add a double box,no room) by pigtail the blk (hot) to upper pole brass screw with blk from fan to same pole silver screw.
sorry if my termoligy is bad but just trying to get a clear understanding of this.
Old 08-23-2008, 01:55 PM   #8
1/2 hot mystified me also!
There are combination switch/receptacle units available or double switch units that occupy only one position in a single gang box!
Old 08-23-2008, 02:30 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
The depends on how the swith was wired.
Let us know what wires are in the switch and we can direct you from there.
Remote with whole house fan? jman1 Electrical 11 05-23-2010 09:07 AM
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 08:46 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing Aspire Remote Smart Dimmer sk72 Electrical 8 03-19-2008 09:16 PM
Hampton Bay Remote Ceiling Fan esqjd Electrical 16 01-14-2008 05:32 AM
