Installing Extra Outlets? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2009, 11:28 AM   #1
installing extra outlets?
When my house was built, I had them install an outlet in the garage on a dedicated circuit. Now I want to run few more outlets off of the original one. How is this done. I can easily route the wire from the original outlet into the attic and back down to where I want them. Do I just connect the 3 wires to the original outlet and do the same to each new one?
Also, should I use 14-2, or 12-2?
mopowers is offline   Reply With Quote
Old 08-11-2009, 11:37 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
Yes, that's it. You'll see that on each receptacle there are two terminals on each side. Run power into one terminal on each side, and out from the other terminal ont he same side. There is usually no way to terminate two ground wires on one receptacle, so you have to "pigtail" it - connect the incoming and outgoing grounds plus a short length of bare wire in the box with a wire nut, and connect the short length of ground wire to the grounding terminal on the receptacle.
If the circuit is on a 15A breaker, you can use #14 wire. If it is on a 20A breaker, you must use #12 wire.
mpoulton is offline   Reply With Quote
Old 08-11-2009, 12:01 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
NO, it is not as simple as black to black and white to white. There are other issues and codes involved, such as box size, stapling, etc.
I would suggest a good boor or two on home wiring to help you with the basics.
Old 08-11-2009, 01:17 PM   #4
Remodeler
adpanko's Avatar
Rewards Points: 150
I agree. I used Black & Decker's "Complete Guide to Home Wiring" as my primer into electricity. Great book. Covers about 90% of any issues or questions you may have about residential wiring. For basic projects like adding outlets on an existing circuit, the book is fantastic and will address any relevant topics such as all the things mentioned in this string of posts (wire type/size, making connections, box size/fill, how to run the wires, how to secure the wires, wire spacing/protection, etc.).
No offense, but judging from your question of not knowing what wire size to use, I'm guessing your electrical knowledge is minimal, so I'd highly recommend you read up on the basics before attempting any such project. Residential wiring is actually quite easy and intuitive after you know the core principals and common code issues.
adpanko is offline   Reply With Quote
Old 08-11-2009, 05:12 PM   #5
A book would definitely be a good idea to learn about home wiring in general, but this particular installation is really not very complicated. Unless he's using pancake boxes or trying to do something weird that he didn't mention, box fill will not be an issue. For NM cable fished in an existing wall, stapling isn't really an issue either.
Old 08-11-2009, 05:27 PM   #6
Point taken.
My point was along the lines of this:
Old 08-11-2009, 05:46 PM   #7
Point taken.
Yeah, that's a point. It's really simple... if you know what you're doing.
Old 08-11-2009, 06:20 PM   #8
Thanks for the input guys.
Do all of the outlets in the garage need to be GFI protected?
I'm in CA if that matters.
Old 08-12-2009, 01:11 AM   #9
Yes, all garage receptacles (as well as outdoor, kitchen, bathroom, and unfinished basement receptacles) must be GFCI protected anywhere in the US.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
installing outlets on an overhang Red Squirrel Electrical 9 08-10-2009 01:14 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
