11-07-2011, 07:13 PM
#1
Installing Electrical Outlet in the place of an old Light Fixture
11-07-2011, 07:39 PM
#2
Pics are not viewable.....
11-07-2011, 08:47 PM
#3
Average Joe/ex-Navy IC3
If the infrastructure goes down, that ups will be worthless.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
11-08-2011, 02:45 PM
#4
Reason: Caption.
11-08-2011, 04:02 PM
#5
Only needed one photo, or just your description. If you want to replace, you just need to go to the local hardware store to get the correct fixture with a three prong outlet. Keep in mind, though the light fixtures with the outlets are only rated for temp use, not long term like a regular wall outlet.
11-08-2011, 04:09 PM
#6
What I want to do is install a regular wall outlet in that junction box. I bought the light fixture adapters for a total of three two prong ports, but the old light fixture can only handle 60 watts of power consumption. The TV has an average power consumption of 75 watts and the old VCR an additional 25 or so. My goal is to install a wall outlet that I have already bought.
11-08-2011, 04:13 PM
#7
The 60 watts is the light bulb rating. Has nothing to do with the outlet rating. I would suggest reading the NEC, and getting a good book on electrical wiring, before doing anything.
11-08-2011, 04:20 PM
#8
I always notice a warning label that says something like this:
"Risk of Fire Max. 60 Watts Type A". I'll upload a picture of the outlet that I bought. All I need is a wiring diagram.
11-08-2011, 04:28 PM
#9
You do not need to load a picture of it. The label is for the max rating of the light bulb in the fixture. Has nothing to do with the max rating of the circuit.
11-08-2011, 04:37 PM
#10
Woulden't plugging a TV and a VCR into one of these equate to plugging in a 100 or so watt light bulb if the fixture can only handle a 60 watt light bulb at maximum? Anyway, I want to hook up a wall outlet to a junction box for permanent use. At the same time, there is also wiring, as seen in the photos above, going to a DC step down transformer for the doorbell.
11-08-2011, 04:50 PM
#11
Again you really need to read the NEC, and a good book on electrical wiring. That Edison fixture plug is only meant for temporary use. And personally I along with a lot of others would like to see that and quite a few other firestarters leave the market.
11-08-2011, 05:11 PM
#12
My equivalent of that is the Canadian Electrical Code. Nothing that I buy from RONA, a reputable hardware store in Canada, is questionable if used safely and installed properly, right?
11-08-2011, 05:17 PM
#13
Electrical Contractor
Simply install a duplex outlet at the box, using one of these cover plates:
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-08-2011, 05:21 PM
#14
Another couple of bucks spent. Thanks for your help. I'm glad that what I am attempting to do is in fact possible.
11-08-2011, 06:27 PM
#15
Does not matter where you buy those pieces from. They are the worst thing next to matches. Best fire starters money can buy.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
