Old 10-16-2012, 02:49 AM   #1
installing electrical and low voltage outlets on unsealed exterior basement walls
How can I install and protect electrical and low voltage (coaxial & Cat6 Ethernet) outlets/jacks if the framing they're attached to sits in front of an unsealed exterior basement wall? The basement won't be sealed beforehand.
anuvanoob is offline   Reply With Quote
Old 10-16-2012, 08:39 AM   #2
No special protection is needed.
The cables and outlet boxes are mounted to the studs in the same manner as for upstairs framing.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 10-16-2012, 04:54 PM   #3
so moisture seeping from the concrete and lath & plaster wall is nothing to worry about with bare electrical wires inches away?
Old 10-16-2012, 05:50 PM   #4
E2 Electrician
stickboy1375's Avatar
I would be more concerned with mold at that point.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
brric (10-16-2012), Speedy Petey (10-17-2012)
Old 10-17-2012, 05:05 AM   #5
Yes, but that's another post. This post is about moisture + electricity
Old 10-17-2012, 07:25 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
What do you think the problem would be? The moisture is NOT going to affect the electricity. If anything it will affect the associated metal.
Old 10-17-2012, 01:00 PM   #7
Moisture is the problem. Mold and/or rot will be problems, if they are not already.
Fix the moisture problem before doing anything.
Otherwise, you may find yourself pulling out everything to get at the problem.
Oso954 is offline   Reply With Quote
Old 10-17-2012, 01:49 PM   #8
fixing the moisture problem is out of scope for this project - the whole basement will be fully finished in a year or two and that's when we'll seal it to address moisture. for now I just need to quickly refinish this small room so it can be my office. its temporary.
