-   -   installing electrical and low voltage outlets on unsealed exterior basement walls (http://www.diychatroom.com/f18/installing-electrical-low-voltage-outlets-unsealed-exterior-basement-walls-160244/)
anuvanoob 10-16-2012 02:49 AM
How can I install and protect electrical and low voltage (coaxial & Cat6 Ethernet) outlets/jacks if the framing they're attached to sits in front of an unsealed exterior basement wall? The basement won't be sealed beforehand.
AllanJ 10-16-2012 08:39 AM
No special protection is needed.
The cables and outlet boxes are mounted to the studs in the same manner as for upstairs framing.
anuvanoob 10-16-2012 04:54 PM
so moisture seeping from the concrete and lath & plaster wall is nothing to worry about with bare electrical wires inches away?
stickboy1375 10-16-2012 05:50 PM
12 Attachment(s)
I would be more concerned with mold at that point.
anuvanoob 10-17-2012 05:05 AM
Yes, but that's another post. This post is about moisture + electricity
Speedy Petey 10-17-2012 07:25 AM
What do you think the problem would be? The moisture is NOT going to affect the electricity. If anything it will affect the associated metal.
Oso954 10-17-2012 01:00 PM
Moisture is the problem. Mold and/or rot will be problems, if they are not already.
Fix the moisture problem before doing anything.
Otherwise, you may find yourself pulling out everything to get at the problem.
anuvanoob 10-17-2012 01:49 PM
fixing the moisture problem is out of scope for this project - the whole basement will be fully finished in a year or two and that's when we'll seal it to address moisture. for now I just need to quickly refinish this small room so it can be my office. its temporary.
