Old 07-12-2008, 10:29 PM   #1
The Carpenta!!!
ManMythLegend's Avatar
Default Installing dryer outlet in laundry room
Check this out...I'm electrically stupid. That's the actual term. I read it in a handman magazine..Seriously..
Anyway, my dillema is this. I'm interested in installing an outlet to fit a dryer plug in a laundry room outfitted with a gas hook up for the dryer. I'm a carpenter so I know basically what I need to do to get started, and I will have no problem installing it in the drywall on the stud. I do not know, however, what electrical components I need (wire, type of outlet, etc.), how high to install it (I think code is 30 inches), how to install it to a breaker, and wether or not I have to remove the gas hookup or if I can just cap it.
I'll take whatever pictures I need to take, and provide any info I need to for help. Please get me started. It's been 2 years and I have a brand new washer and dryer in my garage that I'd love to use. Thanks!
ManMythLegend is offline   Reply With Quote
Old 07-12-2008, 10:44 PM   #2
I am assuming by your reference to capping the gas line, that you would like to install an electric dryer in a location where a gas dryer was previously installed.
Considering your lack of experience with electrical work, I would get a qualified electrician to do the hookup, and a qualified plumber to cap the gas pipe.
You are dealing with heavy currents, most likely at 220V, so this is not your every-day wall receptacle.
FW
fw2007 is offline   Reply With Quote
Old 07-12-2008, 10:52 PM   #3
The Carpenta!!!
I appreciate your concern, but how am I to learn if I outsource everything? I'm fully prepared to run the wiring, install the outlet, and hook it up to the box. I have a 10 kA breaker with the two 20 switches attached that has been off for over a year. It used to go to an old floor heater. I'd like to use that same breaker. I just need some info. Thanks!
I WILL PERSIST UNTIL I SUCCEED.
I AM A LION AND I REFUSE TO TALK, TO WALK, TO SLEEP WITH THE SHEEP.
THE SLAUGHTERHOUSE OF FAILURE IS NOT MY DESTINY.
Old 07-13-2008, 12:09 AM   #4
He can still purchase the materials, and run the wire to save costs on install. As for stating that he needs to get an Electrician, I am sure that if he is competent enough to be a Carpenter, he can understand what gauge wire, outlet type (ie 4 wire), and which section of the NEC.
Old 07-13-2008, 12:11 AM   #5
The 10kA is the rating that the Breaker is rated at to be able to handle a extreme Energy Load from surge on the Electric service going to the house, not the Ampicity rating. You mentioned that you have 2 20 switches, are they showing 20 on the handles on the Breakers, if so, that means that they are 20 amp.
As for the Dryer, check the rating requirements for the Dryer, and is it an older that uses a 3 wire plug, or a newer that uses a 4 wire plug?
Old 07-13-2008, 12:22 AM   #6
Knucklez's Avatar
my friend, i have gotten similar resopnses in the past as above. what i found works better is if you do your homework, research what is needed, draw out your electrical plan and then post for advice. add a quick summary and in the next paragraph be very descriptive in your post & include the state you live in so people know your local codes.
then people will know your competency level better and can give advice accordingly (which may still end up being "hire an electrician").
anyway, in ontario canada..
for electric dryer they are wired using 10-gauge wire with 30-amp 240V braeker; this is a DEDICATED circuit. the washer is on its own circuit.
remember that these machines vibrate so fasten the wiring securely (i.e. use conduit).
ps. i'm not a pro, so wait for others to post.
Knucklez
Knucklez is offline   Reply With Quote
Old 07-13-2008, 02:17 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Can't learn if you don't get your hands on it.
Electric dryer hook up and this will be a new installation.....required 4 wire hookup. The dryer is 120/240 volt and needs a neutral in the wiring. You need 10/3 with ground (H-H-N-Grd)and a nema 14-30R for your plug. You also need to get a 4 wire dryer power cord.
Please reference the below drawing.
Old 07-13-2008, 08:42 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
The only thing I can add to Stubbie's post is remove the existing 2-pole 20A breaker you have and bring it in to a supply house or {cough} a home center.
They can get you the correct 2-pole 30 that you WILL Need.
Then get some 10/3NM cable; you previously measured how much you will need, right? Add a few feet for a cushion.
Get and use a deep 2-gang cut in box, you will NOT get the cable and receptacle in a one gang cut in.
Get the appropriate 4-wire flush dryer receptacle and 2-gang sized cover plate for it.
Follow Stubbie's drawing.
Report back and tell us how great everything worked.
Old sig removed. Thankfully Advanta is dead.
Old 07-13-2008, 12:11 PM   #9
The Carpenta!!!
WOW! Plenty of great of information! Thanks so much. That should be more than enough to get me started.
The dryer allows me to change from 3 wire to 4 wire from a panel on the back. That should be no problem.
Again, I can cut the drywall and install the outlet, run wire, etc. I would just like to know if 30 inches high is standard or if a dryer is different. The other outlets in the laundry are about 4 feet high. Should I just match this one or are those wrong?
Old 07-13-2008, 12:30 PM   #10
Licensed Electrician
jrclen's Avatar
There is no code concerning the height of the receptacle. Put it where the cord will reach it without stretching.
John
jrclen is offline   Reply With Quote
Old 07-13-2008, 12:35 PM   #11
The Carpenta!!!
Just a quick pic of the other outlet. I have other pics of my Laundry room redo in My Photos
Old 07-13-2008, 12:36 PM   #12
The Carpenta!!!
Thanks everybody! I'm sure I'll be back.
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you Part 6 of replacing an old electrical outlet. Next we are going to install a new plate to match our outlet. After that go ahead and turn the power back on. To test... Read More »
Laundry is a fact of life. Many homes run at least one load of laundry on a daily basis. And when you factor in children and pets, you could do even more laundry than that. With your washer and dryer running that much, it's important to keep the noise... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be replacing our outlets and outlet covers. First we need to remove our existing outlets, then we need to clip off our wires and strip them back for our new outlets. Next we need to go... Read More »
The majority of televisions in homes today are built around the cathode ray tube. With plasma televisions, the central element is the plasma in a fluorescent light made up of electrically charged ions and electrons that are free flowing and gaseous. The... Read More »
A portable washing machine is ideal for the person that does not have the room for a traditional washing machine. These models are usually lightweight and can be moved easily from place to place. The following steps can assist you in washing your clothes... Read More »
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 09:08 PM
Combining service closet and laundry room former33t Building & Construction 0 01-22-2008 11:13 PM
Installing Utility Sink In Laundry Room - Main Floor pieman312 Plumbing 13 01-09-2008 10:13 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 12:35 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 05:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
