-   -   installing a dimmer switch from an old switch (http://www.diychatroom.com/f18/installing-dimmer-switch-old-switch-35584/)
wilsonfrench 01-10-2009 04:16 PM
1 Attachment(s)
have a question about installing a dimmer switch...
ok, let me explain what i see in my "old" switch box...
Three wires (Red, Black, White) (enclosed in a white sheathing) are coming into the top of the box...they go up to my light fixture. The RED is connected to the top screw terminal on my old switch. The black is connected to the another black wire coming out from the bottom of the box. The white is "moretted" (?) connected to the sane wire that comes out from the bottom of the box. The black wire that comes from the bottom of the box is connected to the other terminal...but not at its termination point....there is a gap of about 1" cut out of the black insulation...and this "C" shaped copped wire is connected to the terminal...it looks like the photo I have attached. ..
QUESTION:
My dimmer has three wires...(two black and a green...I know where the green goes, but how / where do I connect the two black wires...
it seems that I would have copper wire exposed somewhere...or do I connect three, or cut one (the black that has its exposed copper to the terminal)...
any help would be appreciated. thankss
dSilanskas 01-10-2009 06:16 PM
You have the wrong dimmer. You have a single pole dimmer you need a 3 way dimmer that is why you are confused.
Ultrarunner2017 01-10-2009 07:28 PM
Do you have slack on the wires in the switch box?
What you need to do is:
1) Remove the old switch
2) cut off the splice on the black wires, including the bare "C" part that was wrapped around the screw of the old switch.
3) Strip both black wires again.
4) Splice the two black wires plus one of the blacks from the dimmer switch under a wire nut.
5) Attach the other black wire from the dimmer to the red wire.
Apparently, the black wire leaving with the red and the white at the top of the box is an always-hot wire that goes to the light fixture, and is spliced to another part of the circuit. You should also then have the white wire in the light box spliced to another white along with the white from the fixture.
If not, then where does the black wire leaving the top of the switch box go?
dSilanskas 01-10-2009 07:38 PM
KE2KE he has the wrong dimmer for starters :whistling2:
InPhase277 01-10-2009 08:00 PM
No, he doesn't. He has a single pole dimmer and an existing single pole switch. KE's advice is correct.
dSilanskas 01-10-2009 08:27 PM
Ohh yes I see it now I misread it my mistake:laughing:
wilsonfrench 01-11-2009 01:25 PM
1 Attachment(s)
like this? see photo...
I do not understand the "language" you are using..slicing? splicing? wire nut?..why do I have to cut off the spliced part? can I not just unbend it from its "C" position? or its "clockwise" curve?...this would save me some length of wires..see photo...is this correct?
basically, then, I have:
connect black dimmer (#1) to red switch
connect black dimmer (#2) to black black wire going north and to black wire going south?..so, to look at it, I would have three blacks (DIMMER + other two) all connected together? and one black connected to a red?
jbfan 01-11-2009 02:05 PM
That is correct.
