Installing A Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2007, 01:34 PM   #1
Installing a dimmer
Hi guys. I just need a little help installing a dimmer switch. Heres the old and the new, what wire goes where? Thanks in advance!
xray328 is offline   Reply With Quote
Old 02-24-2007, 01:40 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
NONE!
You have a 3-way switch and a single pole dimmer.
You need a 3-way dimmer.
On the dimmer, the "odd" color (likely black) goes to the wire on the "common" terminal on the switch.
The two like colors (likely reds) on the dimmer go to the two other wires on the switch. It matters not which goes to which.
Green is ground.
Speedy Petey is online now   Reply With Quote
Old 02-24-2007, 01:43 PM   #3
The Home Depot guy told me that I only needed a 3 pole if I had two switches controlling one light. O'well, back to the store I guess. I'll be back...
Old 02-24-2007, 02:32 PM   #4
You DO have (at least) two switches controlling that light. That IS a 3-way switch with the proper number of wires.
Old 02-24-2007, 07:12 PM   #5
Got it working. The switch has a green ground wire, but theres no ground hook up anywhere in the box. Is the ground needed? If so, wheres it hook up to? Thanks again!
Old 02-24-2007, 07:31 PM   #6
From the colors of the wires in your box can I assume you have conduit? Just connect the ground to the box or a ground wire in the box. There should be a threaded hole for a ground screw.
Glad you go it working!
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
