#16 | |
Installing dedicated outlet for generator onlyQuote:
Do not PM with questions that can be asked in a forum. I will not respond. |
#17 |
Installing dedicated outlet for generator only |
#18 | |
It was a dark and stormy
You know, lead-acid batteries give off hydrogen while being charged so there is a danger of an explosion unless they are well ventilated. At 100% efficiency, the energy in 0.77 gal of gasoline = 1.1 gal of propane. |
#19 |
Yoyizit, the batteries are 6V 220 AH each and wired serial and parallel for 12V with a total of 880 AH. They are situated in one of the basement compartments under the RV, which was ventilated for this purpose.
I had them installed by professionals because I needed a set up where I could put a dedicated outlet in the slide area of the RV where my office is and I couldn't figure out how to do it. They rigged a very clever system of a smaller rod of PVC going into a larger rod with a coiled electrical cord inside which goes in and out with the slide and up through the floor of the RV to the outlet. It is pretty cool so thought I'd share that! Insofar as the propane, I can appreciate what you are saying, but I've been lugging 6 gas cans around with me for the last year to feed my generators. It is no fun manually filling generators when it is your only source of energy! The propane tank holds 175 gallons and would last quite a while for the amount of energy I use. I would also still use the two gas generators, plus the one I have in the RV, but propane is much more convenient hardwired to the house. |
#20 |
So, ~11 kwh from the batteries can run the average house for 11 hours and you need about 18 kwh of energy to recharge them.
Or not. Here's a link on how to squeeze the most energy out of your batteries for a setup possibly similar to yours. http://photovoltaics.sandia.gov/docs...atpapsteve.pdf This gets complicated. . . And with batteries in parallel I'd check with a hydrometer that each battery is doing its share. Series charge/discharge is probably a better arrangement. 175 gals of propane at 100% efficiency gives you 4700 kwh of energy. Maybe you'll get 1000 kwh of elec. I wouldn't mind going off the grid myself Last edited by Yoyizit; 10-14-2009 at 07:44 PM. |
| Display Modes | |
| Installing a new in-line electrical outlet | Nedly83 | Electrical | 5 | 09-01-2009 08:44 AM |
| installing an outdoor outlet | bcatl | Electrical | 4 | 06-18-2009 06:56 PM |
| wiring a dedicated switch to a outlet | Michel | Electrical | 2 | 09-18-2008 07:25 PM |
| Installing dryer outlet in laundry room | ManMythLegend | Electrical | 11 | 07-13-2008 11:36 AM |
| Help on installing a 220v outlet | BobRankin | Electrical | 24 | 10-23-2007 06:32 PM |
