Installing Conduit/Mounting - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-08-2011, 07:46 PM   #31
Curious Youngster
TssCman123's Avatar
Originally Posted by Techy View Post
type 'so' cord or similar.
but exit signs are not legally allowed to be cord and plug connected
That is usually because someone may try to unplug the device, the plug for my devices will be inside of a sealed electrical box, plus exit signs aren't required in my house, so that code probably doesn't apply to my situation.
I can't find that wire at Lowes, so what category would I find this cable under?
  • Low Voltage Wire
  • Non-Metallic Wire
  • Service Entrance Cable
  • Specialty Wire & Cable
  • THHN Wire
As to my previous post, the THHN wire with the plug body would still be unsafe even in a sealed electrical box?
TssCman123 is offline
Old 09-08-2011, 08:06 PM   #32
Sparky
Rewards Points: 510
http://www.lowes.com/pd_56592-295-55...0051&langId=-1
Techy is offline
The Following User Says Thank You to Techy For This Useful Post:
TssCman123 (09-08-2011)
Old 09-08-2011, 08:10 PM   #33
Curious Youngster
TssCman123's Avatar
Thank you!!
Now if anyone could answer my question from my few previous posts, then I could end this thread with a few more questions.
Old 09-09-2011, 08:28 PM   #34
Curious Youngster
TssCman123's Avatar
EDIT: Instead, if someone could just answer my question above, and I will create a new thread regarding my other questions.
Old 09-10-2011, 01:54 AM   #35
Yes, unsafe. A plug body is listed for use with a flexible cord and not with individual conductors.
If you are already going to put on an extension box then run your conduit out of the extension to another box on which you could install an exit sign. If the original box in the wall is metallic AND already bonded AND you are using EMT, IMC, or RMC conduit then the pesky green wire is not needed in the conduit run.
Dante711 is offline
Old 09-10-2011, 04:09 AM   #36
An old Tradesmen
Rewards Points: 7,380
It would still be a code violation.
We don't allow threads to continue where the OP(yourself in this case) seem to be intent on not following code, despite the numerous the times they have been told its a code violation. By many pros in that trade.
Thread closed.
beenthere is online now
Closed Thread
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing plinth blocks? Badfish740 Carpentry 6 02-09-2009 10:45 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
