Installing Conduit/Mounting - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 08-29-2011, 07:05 AM   #1
Curious Youngster
TssCman123's Avatar
I will be running a rather short metal conduit from an electrical box on my ceiling to an electrical box near the bottom of the wall. I am new to conduit, and have a few questions.
Am I just able to run the 12 awg neutral, hot, and ground wires all in the same 1/2" metal flexible conduit?
Do I need to ground the metal conduit?
If I mount the electrical box on the drywall without studs (with the "butterfly" screws), what is the maximum weight it can hold?
If I mount the electrical box to the stud, it is safe to screw through the wood, right? In regards of the wood splitting.
TssCman123 is offline
Old 09-05-2011, 11:12 AM   #2
Curious Youngster
TssCman123's Avatar
This is a bump.
Old 09-05-2011, 11:18 AM   #3
Rewards Points: 14
you can run a 14 ground wire. yes you have to run all conductors in the same conduit. You could just use 14-2 or 12-2 bx armoured cable instead of running your own flex. I would mount to the studs. sounds like you are adding a light. Way more stable to screw to studs.
thefatpigeon is offline
The Following User Says Thank You to thefatpigeon For This Useful Post:
TssCman123 (09-06-2011)
Old 09-05-2011, 11:27 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
No, he can't.
For a 20A circuit using #12 wire the ground MUST also be #12.
Speedy Petey is offline
Old 09-05-2011, 11:37 AM   #5
Curious Youngster
TssCman123's Avatar
Thank you for your quick reply. Yea, I'm going to mount to studs, because the drywall anchors would probably fall out of the drywall. After Googling, I discovered that drywall anchors can only hold a few pounds.
I'm just going to stick with the conduit, but would 1/2" be wide enough?
I've mounted an electrical box to a stud recently, and I heard something that sounded like the stud splitting, is this safe?
Does anyone know anything about grounding the conduit or electrical box? If I get one of those plugs that plug into an outlet receptacle, and have terminals for wires to be connected, should I just connect a wire in the ground terminal, and then connect the other end of the wire to the electrical box?
Should I use 12 AWG solid THHN wire for the hot and neutral? What kind of wire should I use for the Earth/ground wire? Keep in mind that I am sending this through electrical boxes and metal flexible conduit?
Old 09-05-2011, 11:42 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Does your area require conduit, or can you use romex?
You can use solid or stranded wire for all conductors.
If the circuit is 20 amps, then you must use #12 for all conductors.
If this is a 15 amp circuit, you are allowed to use #14 gauge conductors.
Metal boxes have a place for a bonding jumper tha connects all ground together.
jbfan is offline
The Following User Says Thank You to jbfan For This Useful Post:
Old 09-05-2011, 12:22 PM   #7
Curious Youngster
TssCman123's Avatar
I think my area allows Romex, but I don't want to use that because my dogs may chew through it. (this is in a home)
I'm doing the same "project" in many rooms, some rooms have a 15amp circuit and others have 20amp circuits, to avoid buying dI'ifferent types of wire, I'm planning to just 12 gauge wire for all circuits.
I'm using solid, because I heard stranded isn't best when used more than 10 feet, and I'm running about 17 feet.
Regarding the metal boxes, would you be able to find an image off of Google to show me what you are talking about, because I've seen many different types of metal boxes, and I'm not sure which kind to get.
I'm still having trouble gasping everything about the ground wire. What kind of wire do I use?
I have attached an image of how I plan to wire the device. I am just getting one of those plugs that plug into an outlet receptacle, and that can have wires connected to. Then, I'm going to connect the wires, run them through conduit and 2 electrical boxes, then to an exit sign. Please check to make sure to I have the ground wire going through everything correctly, keep in mind that I need to ground the metal exit sign. Also, please tell me if I'm supposed to do anything special with the ground wires.
If I have the conduit connected to the electrical boxes, do I need to ground the conduit also? If I have both electrical boxes connected to the conduit, do I need to ground both electrical boxes, or just one?
Old 09-05-2011, 12:45 PM   #8
Licensed electrician
Rewards Points: 1,502
You cannot install a plug for a receptacle onto the conductors as shown above.
Is this related to the post about the exit light in the living room?
Jim Port is offline
Old 09-05-2011, 12:54 PM   #9
Curious Youngster
TssCman123's Avatar
i
If I read your post right, I am not installing the plug instead of an outlet. I am connecting wires for an exit sign to the black plug device as shown in the image, then plugging that plug into an outlet receptacle. This is great for areas that need an emergency light or exit sign, but do not have a spot to be hard wired.
This topic was supposed to be about running conduit, and the other topic was about wiring the exit sign. Somewhere upon all of the posts, the topic got switched over to wiring the ground wire. B.T.W., in the other topic I was going to put the exit sign in a hallway/corridor, not a living room.
Old 09-05-2011, 12:59 PM   #10
Now that you have clarified, I will again state that you cannot add a plug onto the conductors as shown.
Jim Port is offline
Old 09-05-2011, 01:03 PM   #11
Curious Youngster
TssCman123's Avatar
Oops, sorry about that, I thought you meant something else.
So what kind of conductors should I be using?
Old 09-05-2011, 01:33 PM   #12
Curious Youngster
TssCman123's Avatar
I really think the wires are okay for this device, why wouldn't they?
Old 09-05-2011, 04:53 PM   #13
jbfan's Avatar
Rewards Points: 420
Maybe you should consult a pro to do this job for you.
jbfan is offline
Old 09-05-2011, 05:33 PM   #14
Curious Youngster
TssCman123's Avatar
I've installed an exit sign that has plugged in before, except that one had the end of the extension cord cut off, and then it was wired to the exit sign. I wish to wire an exit sign to plug in a receptacle, but have the wires going through conduit for protection. I know how to do all of it, except for the grounding. I am just confused as to why those conductors aren't correct for this job. I hope he/she means wires by saying "conductors", or I'm really confused.
Thanks for the suggestion, though.
Old 09-05-2011, 05:35 PM   #15
jbfan's Avatar
Rewards Points: 420
And this was done incorrectly!
jbfan is offline
Closed Thread
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing plinth blocks? Badfish740 Carpentry 6 02-09-2009 10:45 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
