Installing Chandelier Exsiting Dimmer Switch. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 09:12 AM   #1
Installing chandelier exsiting dimmer switch.
There r 3 black, 3 white and 1 red wires. I hooked up black and white wire from chandelier and have power but no dimmer switch. Please help!
Wesmangolf is offline   Reply With Quote
Old 12-04-2011, 09:15 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
How was the old fixture wired?
I assume to the whites and the red. Try that.
Make sure you ground it properly.
Old 12-04-2011, 09:19 AM   #3
There wasnt anything there. Just the box. Three twisted together black wires and 3 twisted together white and one single red wire. I connected the white to white and the other to black. The chandelier has power, but its not controlled by the dimmer switch. ugh.
Old 12-04-2011, 09:19 AM   #4
OK, like I said, try the red instead of the black group.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Wesmangolf (12-04-2011)
Old 12-04-2011, 12:27 PM   #5
Ok, so hooking up to red makes the dimmerswitch capable of turning the chandelier off and on. But it will not dim?? ugh.
Old 12-04-2011, 12:32 PM   #6
Bad dimmer then.
Old 12-04-2011, 12:36 PM   #7
Saw it working when the previous owner had a fixture there. I wonder if the dimmer switch is wired backwards? Would it still work but not dim? Thanks for your help bud.
Old 12-04-2011, 01:22 PM   #8
No, it is doesn't matter how it is wired. Typically dimmers have just two black wires.
Most dims are pretty sensitive. Any shorts or sparks can kill them.
Old 12-04-2011, 01:25 PM   #9
Sparky
Rewards Points: 510
if you have CFL bulbs in the fixture, they must be a special dimming type, also.
Techy is offline   Reply With Quote
Help installing dimmer switch!! older house catpace Electrical 1 04-18-2011 03:05 PM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 07:10 AM
Replacing a wall outlet dimmer switch with a rocker switch Lonepine Electrical 1 01-05-2010 10:18 AM
Installing a chandelier preciouschristy Electrical 2 07-06-2009 04:35 AM
Weird problem replacing dimmer switch cdale600 Electrical 9 01-20-2009 08:31 AM
