Installing A Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 02:22 AM   #1
Rewards Points: 51
Installing a chandelier
So- I started with a circuit where a switch controlled a receptacle. I installed a chandelier in the room. The cable that connected the switch to the receptacle was accessible in the attic, so I cut the cable, installed a junction box, and attached both the receptacle and the chandelier to the switch, inside the junction box.
My circuit tester shows that both the receptacle and chandelier are hot when I flip the switch, but neither of them will light. (I plugged a floor lamp into the receptacle to test it). I tried reversing the wires in the chandelier (even though my instructions say it shouldn't matter). Still nothing lights. I've tried new light bulbs, too.
My inclination is that by splitting the circuit, I've somehow diminished it- but before I go messing around in the attic again, I was hoping someone could give me an idea. What bothers me is that the tester shows that I have power, but nothing actually working. Very confusing.
preciouschristy is offline   Reply With Quote
Old 07-06-2009, 02:37 AM   #2
300zx's Avatar
Post
When you made a splice in the attic was the wire you put in the j-box a 3 wire or 2 wire,sounds like prob 2-wire 1-hot,1 nutral ,1 ground (You have no nutral wire in j-box) http://www.wiringhelp.com/electrical...-a-switch.html Look at second switch setup
300zx is offline   Reply With Quote
Old 07-06-2009, 04:35 AM   #3
Generally, homeowners shouldn't do electrical work like this..
You could have done a dozen things wrong. My guess is that you tapped into a switch loop instead of a switch leg. If there is only one cable in the sw box, that's the case and it aint gonna work.
If it is a switch leg, the neutral(white) connection is not tight.
Call someone to fix your mess before something catches fire.
220/221 is offline   Reply With Quote
Tags
lighting , switch , wiring
heavier chandelier??? frgwtchr Electrical 13 07-25-2009 11:08 AM
Help with chandelier saluki Electrical 11 05-25-2009 07:18 PM
need help with chandelier kreynolds Electrical 4 11-05-2008 09:40 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
