Installing Central Air Question About Conduit From Disconnect To Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 08:09 AM   #1
Installing central air question about conduit from disconnect to panel
Hi, I have been lurking here for a while and enjoy the many informative posts.
Anyhow, I am installing my own central air system. I got an HVAC guy that is going to braze my lines and check my freon and stuff for a $100.
I have done lots of wiring before but I am unsure of something.
So I setup my outdoor wiring and my safety disconnect. I used those a/c whips (flexible conduit). Now after the disconnect where it comes into the house, it is long enough to connect the conduit directly to the panel. I did buy some romex and a junction box thinking it would not end up being that close. Is it allowed to run the conduit from outside (from the disconnect) directly to the panel? I could not find the answer anywhere. I have a copy of the NEC but its so hard to find answers in there sometimes.
Also my thermostat wire is 20 gauge and the thermostat wire in the condenser is 18 gauge, is it okay to connect those 2 together with differing gauges? I did not notice until after I ran the thermo wire through the conduit and all the way to the furnace.
angelas111 is offline   Reply With Quote
Old 05-27-2011, 08:25 AM   #2
Licensed electrician
Rewards Points: 1,284
Yes, you can run conduit from the back of the disconnect directly into the panel.
Old 05-27-2011, 08:37 AM   #3
thanks, what about from the side of the disconnect into a hole in the house to the panel?
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 10:53 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 04:27 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-04-2008 12:07 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
