Old 03-09-2011, 01:07 PM   #1
Installing ceiling light in small den
Hello. I have a small den that I want to install a light in. There is a switch in the room that currently only controls the top plug of an electrical outlet. The only reason I use that plug is for a lamp since there isn't any light in the room!
My question: Does it work to just unhook the wires attached to the plug, from the light switch, fish them out of the wall and attach them to the new light?
I really have very little knowledge when it comes to how you would wire a home or anything like that, so I don't even know if I'm able to just get in the attic and fish out the wire. My attic is obviously heavily insulated, so I didn't want to start digging up insulation without knowing what I was looking for.
Thanks for the help!
pansenbaer is offline   Reply With Quote
Old 03-09-2011, 02:04 PM   #2
joed's Avatar
You should be able to fish a new cable to the switch and rewire it to control the fan/light.
If you want the receptacle to be still switched so can switch the lamp then you probably need to fish the cable to the receptacle.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-09-2011, 02:09 PM   #3
Originally Posted by joed View Post
You should be able to fish a new cable tot he switch and rewire it to control the fan/light.
Well, I don't really need the outlet to he on the switch so I was thinking it would be easier to just use that wire to control the new light.
Unless you think it would be just as easy to run a new wire.
Old 03-09-2011, 06:48 PM   #4
joed's Avatar
You have to run a new cable to either the switch or the receptacle. The current cable between the switch and the receptacle either will power to the receptacle or from the receptacle to the switch in the new configuration. If you need us to tell you how to do it you are going to have to open the reptacle and the switch and tell how the wires are currently connected. Then we can tell you how to change it. Also tell us if the new cable will be going to the switch or the receptacle.
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
Installing a ceiling fan in the kitchen gerb Electrical 12 06-23-2008 08:49 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
