Installing A Ceiling Light Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2006, 10:15 AM   #1
Rewards Points: 87
Installing a ceiling light fixture?
I have a room that does not have an electrical box in the ceiling where a light could be installed. The switch on the wall turns an outlet on/off, where we have a lamp plugged. I need more light in the room since it has 9' ceilings.
I was thinking of installing a simple, lightweight fixture into the ceiling and running the cord across the ceiling and down the corner to the outlet that is wired to the switch. I saw at a hardware store there is plastic sheathing that will adhere to the ceiling/wall surface that can hide wires for a better appearance. I realize there will be some visual evidence of the wiring, however better than nothing.
Does anyone have any ideas for a weekender do-it-yourself guy on adding more light???
The place is only 10 years old and not sure why there is not conduit or junction boxes even installed under the drywall to wire in a light down the road.
DK75 is offline   Reply With Quote
Old 01-12-2006, 06:43 PM   #2
its not that hard to install a light mount with the power hidden like normal. you may be able to find an electrician to do it " on the side" on a saturday with help from you. if you have attic access that makes the job easier. i always thought those plactic wire runners were tacky. otherwise you could simply hang a light in the center of the room that hangs down by a chain and run the chain and cord across the ceiling by plant hangers and down the wall and plug it in the wall socket.
THEBIGPUNN is offline   Reply With Quote
Old 01-12-2006, 07:15 PM   #3
2nd half
DK
Have you tried opening the window blinds?:D
jmic is offline   Reply With Quote
Old 01-12-2006, 10:24 PM   #4
Rewards Points: 87
Unfortunately I don't have attic access so I can't get through the ceiling. .
Old 01-12-2006, 10:55 PM   #5
i had the same issue in an add-on rec room, no attic. so i bought a ceiling light that plugged into an outlet and hung that.
Old 01-13-2006, 03:54 AM   #6
rdp
Rewards Points: 87
DK75 - There's always this: http://www.theledlight.com/ice_panels.html
powrus is offline   Reply With Quote
Old 01-13-2006, 12:25 PM   #7
how to run the light
1. use a dry wall saw to cut a 8 inch square about 6 inchs above the light switch.
2. cut another 8 inch hole about 2 inchs below the ceiling right above the light switch,
3. cut another 8 inch hole on the ceiling right above the top wall hole.
4 locate the center of the room, (buy a ceiling mounting bar kit. Get one that you can hang a fan off of. it is made better) use the box from the kit to mark the center of the room, cut the around the hole.
now take your wire and feed it through the hole over by the light swithc and run it up to the second hole. take a drill with a long bit and at least a 1/2 bit and drill straight up through the header. feed the wire through the header, you should be able to use both hands to feed it through and pull it through.
Now with a "electrical fish tape feed the tape through the center of the room hole. and use your hand and reach through the ceiling hole by the light swith take the wire and fasten it to the tape. (use electrical tape so it does not fall off)
now pull the wire through the center hole.
ok now feed the wire through the wiring box. now feed the box and mounting bracket through the hole and fasten it per the instructions on the box,
After you have the wire ran make sure you hook up the electrical corectly.
If you don't know how just ask we can tell you how to do that
If you don't know how to patch drywall just ask,
Drywall patching is very easy.
Earl
earl hall is offline   Reply With Quote
Old 02-27-2006, 09:10 AM   #8
Smile
is it a two story house?
if so is there a room above the room where you are installing the fan.if so,you will have a problem running the wire inside the wall to the switch.
JOAT is offline   Reply With Quote
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 04:55 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 09:40 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
