Installing Ceiling Fixtures In Garage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 09:13 AM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,404
Try starting fresh, with explaining actually what is in your first "light" /receptical box....
Then your second.....
Do you have a multimeter and are you able to asertain what is hot and what is not???
MTN REMODEL LLC is online now   Reply With Quote
Old 06-09-2013, 09:22 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by brentalight View Post
No. I'm trying to plug the shop lights in by converting the existing fixtures to ones that have a ground plug.
You are doing exactly what I have described and created a code violation. You have installed receptacles in a garage (most likely) without GFI protection.
Originally Posted by hammerlane View Post
But we do not know what is upstream of this receptacle.
Hardwired garage lighting has never been required to be GFI protected. Unless the garage is detached and the entire garage is on a GFI protected circuit, there is a very good chance that the new receptacles are not GFI protected.
Old 06-09-2013, 09:22 AM   #18
I just got the first light to work again! I had wired it up bypassing the end of run loop to the switch. I have that light working now. The black wire to the second light is next. What do I wire that to in the first light? Do I need to splice into the red wire coming from the switch?
brentalight is offline   Reply With Quote
Old 06-09-2013, 09:24 AM   #19
K buz. I will have someone come over and wire the whole circuit GFI. Right now I'm just trying to get light in my garage again.
Old 06-09-2013, 09:29 AM   #20
k_buz's Avatar
Don't worry, I know you won't. My posts were more directed at people searching the site for the correct way to do it.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
MTN REMODEL LLC (06-09-2013), sirsparksalot (06-09-2013)
Old 06-09-2013, 09:41 AM   #21
Resi EC
Rewards Points: 252
Red wire? first I've read about a red wire.
I'd imagine if we knew all the wires in all boxes pretaining to these lights it would be easier to help
including the switch
Gac66610 is offline   Reply With Quote
Old 06-09-2013, 09:46 AM   #22
Resi EC
Rewards Points: 252
A little confused on what this means. Did you buy one of these adaptors to screw into the single bulb fixture so that you can plug the new shop lights into?
I think hes talking about one of these, but with a grounded receptacle and no pull chain
The Following User Says Thank You to Gac66610 For This Useful Post:
hammerlane (06-09-2013)
Old 06-09-2013, 09:52 AM   #23
Yep thats it and I got both working now. The red wire was from the switch. Thanks for everyones posts and I will have the circuit switched to GFI. I have a buddy who is an electrician but he is out of town this week hence my lame attempt at trying to do this myself.
Old 06-09-2013, 09:55 AM   #24
EDIT: X POSTED.... Congrats!
Old 06-09-2013, 01:39 PM   #25
Resi EC
Rewards Points: 252
I skipped the first line you had there ... learned that one from a buddy
Installing 220 in garage for future welder - questions! wguttrid Electrical 7 01-31-2013 07:30 AM
Garage ceiling joist, bracing, and insulation ACR_SCOUT Building & Construction 11 01-21-2013 06:05 PM
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 12:58 PM
20x22' detached garage ceiling joist advice amp2oo1 Building & Construction 11 08-01-2012 09:13 AM
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 07:16 PM
