Installing Ceiling Fan Where There Is No Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2008, 08:35 AM   #1
DIY Expert in Training!
Installing ceiling fan where there is no light?
My wife and I want to install a ceiling fan in our nursery and also our master bedroom. Currently there is a switch that powers a wall outlet. We can access the ceiling via the attic above. I am not sure how I can power this considering the current switch powers an outlet.
What is the correct way to do this?
gone_fishing is offline   Reply With Quote
Old 06-10-2008, 10:04 AM   #2
Power Gen/RS Engineer
Rewards Points: 566
The first thing I'd do is cut the power and remove the switch plate and switch. If you have only two wires/one cable in the box then this would imply that the source is at the receptacle. If on the other hand, you have two cables in the switch box with both white wires nutted together then you know that the power comes to the switch box (this assumes that your house is wired with Romex; if your construction is pipe/wire, the configuration could be just a skotch different).
Assuming that the power originates in the switch box, you'll want to run a new 3/c cable from that up to the ceiling. From the attic, you should be able to move the insulaton and find the top plate of the wall. From there, you can drill a hole down through the plates and fish in the cable. Next, you'll need to install a ceiling box that is rated for attachment of a ceiling fan.
This should get you started. The only thing that I cannot answer right off the top of my head is whether the addition of the new cable will exceed the volume allowance of the box. Is the switch currently installed in a single gang, non-metallic box?
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 06-10-2008, 05:38 PM   #3
Rewards Points: 80
Dittos on the 3 conductor cable Jimmy. Follow The Big mans instructions. Make sure you have a good support for the fan. A 2x4 will make for excellent mounting of your fan rated box. Find out what the switch controls? (receptacle?). If so, you can use a double switch on a single gang box. One switch for the recept and one for the fan. Find the power wire (hot) for the switch. Attach 2 - 6" wires to this hot wire with a wire nut. Then connect the 2 hots to both switches and connect the fan and the recpts to the other 2 terminals on the double switch. The biggest part of this job will be getting the cable from the switch box to the fan rated box in the ceiling.
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
