Installing Ceiling Fan From Scratch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-11-2012, 05:08 PM   #16
I have a better idea of what to do now but it doesn t explain why I have so many wires.
I think that the tab isnt off the hot side just broken, which really mean that its still connected to the lower part.
Worst case I buy another one and meter the wire before reconnecting it.
Ill let you know later
Thanks for your info.
feel is offline   Reply With Quote
Old 04-11-2012, 05:23 PM   #17
Pure Genius
Rewards Points: 150
You have power in power out and a switched leg to power the switched portion of your receptacle. I would break the tab off completely between the hot terminals and then test. Sounds like your switch may be going bad.
Dierte is offline   Reply With Quote
Old 04-11-2012, 06:09 PM   #18
Yes I will do that tonight take off the whole tab on the hot side and test it. Why is evstar talking about taking off the tab on the neutral?????
I thought only the hot side had to be off.
Old 04-11-2012, 06:56 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Do not remove the tab on the neutral side. That might result in some bad consequences.
Old 04-11-2012, 07:34 PM   #20
What he said!!
Yikes. I'll be more precise in my posts in the future! What I meant was that I agreed that testing it all out would be extremely difficult in that configuration.
Evstarr is offline   Reply With Quote
Old 04-12-2012, 10:04 AM   #21
Ok are you ready for this..................................
I checked the tab on the hot side and it was off .
I then checked the voltage while a lamp was plugged in the upper part (switched leg) and it was 0 ish volt. When I unplugged the lamp its 96 volt.
The others xtra wires are just wired to my other bedroom . If I take them off I have no electricity in my other room. It looks like both bedroom are in series. I will buy another receptacle with screw today. It seems very basic after all 1 black (hot) , 1 white (neutral), 1 green (ground) for the lower part of receptacle. On the upper 1 red (switch) 1 white (neutral)
Installing a ceiling fan with existing 3.5" light fixture box? Superorb Electrical 14 04-03-2012 02:05 PM
Installing a new ceiling light scenario KUIPORNG Electrical 6 10-12-2011 02:35 PM
Installing Ceiling Speakers in Pre-wired Home heywazzupdude Home Theater 2 12-27-2010 11:12 AM
Installing ceiling fan in double wide JANKEL Electrical 2 07-03-2010 01:01 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
