Installing Ceiling Fan With No Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 12:54 PM   #1
Installing Ceiling fan with No Circuit Breaker
I live in a basement apartment, with no access to the circuit breaker panel. Is it possible/safe to put up a ceiling fan with the breaker switch still on?
The wires are there, just swapping out the lighting fixture for the fan fixture.
jadoiron is offline   Reply With Quote
Old 08-15-2010, 12:57 PM   #2
Electrician
Rewards Points: 788
Short answer is no, breakers should always be off before doing electrical work.
Long answer depends if this is a new install or a swap out. If your just swapping an old fan out for a new one, turning the switches off will be a safe option.
If you need to run new wires for this I would not recommend doing this live, find a way to get access to the breakers.
darren is offline   Reply With Quote
Old 08-15-2010, 01:05 PM   #3
Here if you are renting the Apt you are not supposed to do any electric work
Landlord is reponsible for hiring someone
If you do the work you are liable if anything goes wrong
Old 08-15-2010, 01:49 PM   #4
Electrician
Proby's Avatar
Shutting off the switch may or may not be just as effective as shutting off the breaker, it depends on how the circuit was wired. Without knowledge of this, you might be getting yourself into a sticky situation.
Further, you will most likely have to upgrade the ceiling box to a fan rated box. You can't just hang a fan from a fixture box.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-15-2010, 08:21 PM   #5
Electrician
Proby's Avatar
I can't read Yoyizit. He seems very smart and he is certainly very nice. but sometimes he adds "2 plus 2" and comes up with "Zebra".
Old 08-15-2010, 10:24 PM   #6
I think the most viable solution here is for jadoiron to speak to his/her landlord and explain the situation and first seek permission to even have a fan, then request it installed by a professional (possibly at the OP's expense). No liability issues to deal with, no potential danger to be concerned with, and no fear of an eviction notice looming in the future. It's a win-win for all, unless the landlord says no.
One thing you'd not want to deal with is an angry landlord. "Tinkering" with his house wiring could make him angry. Angry enough to ask you to leave the premises, and/or void/terminate your lease agreement (if you have one).
But I do have one question... how high is the ceiling in the basement? Can it safely accommodate a ceiling fan at all?
User78992 is offline   Reply With Quote
Old 08-15-2010, 10:41 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I would ask to get access to the panel after asking permission to do this work. Once the panel is located and proper breaker shut off, add a lock so it can't be turned on, since it sounds like it's not a private box and maybe someone else could potentially have access to it. Then do the work, and then go turn on the breaker.
They key here is getting the permission first. Better safe then sorry.
Old 08-15-2010, 11:47 PM   #8
I think the fact that the OP asked the question would suggest he is not qualified for such action. I would also never recommend a switch be used, have worked on to many K&t, and diy circuits with switched neutral. I started out working on live circuits when I was in the Navy due to necessity and with proper equipment but I don't recommend it to anyone who has to ask.
hayewe farm is offline   Reply With Quote
Old 08-17-2010, 08:38 AM   #9
Still working on a reply.
Old 08-18-2010, 10:21 AM   #10
Electrician
Proby's Avatar
Originally Posted by Yoyizit View Post
Speaking of which, I think I can help you solve what you believe to be your problem - me.
If you can figure out why I am still on this forum you may be able to figure out a way to get me off of this forum.
What's your deal?
Tell me about yourself, I'm interested in knowing.
Tell me why you believe you are a problem.
Old 08-18-2010, 10:47 AM   #11
the Musigician
DangerMouse's Avatar
Originally Posted by OnThePike View Post
clearly state that you are not a licensed professional and that the responses you provide are strictly your opinion and in some cases, be verified by a licensed professional qualified to do so.
In each and every thread there is a warning, to wit:
We, as a forum, accept all opinions (good or bad, you decide) and it's the responsibility of the reader to decide the correct course of action.
I personally will never work on a hot circuit, though I know some who do it all the time.
Rudeness, name-calling, etc. will be removed. We're here to help. Period.
DM
Old 08-18-2010, 11:12 AM   #12
Electrician
Proby's Avatar
If you want to play word games, either PM me or join me on some forum run by Sophists and/or Spin Doctors.
The issue here is that I am not playing word games, I am trying to have an open, honest discussion.
You, on the other hand, have been linking to wikipedia and expecting people to know what you're talking about. For some strange reason you are refusing to have a discussion, your posts are borderline trolling.
If you don't want to participate, then that's fine. But there is no reason to act the way you have been.
Old 08-18-2010, 11:27 AM   #13
the Musigician
He got his answer. Don't need the rest of the arguments.
DM
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 06:38 PM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 08:54 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
