Installing Ceiling Fan-no Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2010, 06:44 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
installing ceiling fan-no attic
I am looking to install a ceiling fan in room that has no ceiling lights. The room only has a switch that controls a few outlets. I found this odd seeing the house was built in 1988. The house is a cape, so typical setup with no attic space but closets in the eaves. Im also looking to put some can lights in. Is there anyway to do this without ripping down the ceiling?
Millertyme is offline   Reply With Quote
Old 05-05-2010, 09:41 PM   #2
So you have no access above the ceiling? This makes me think you would need to use surface raceway. Wiremold's 500 or 700 series would work for this - and I know there is a fan-rated box available for it as well.
Unless I'm misunderstanding?
brich is offline   Reply With Quote
Old 05-05-2010, 09:46 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Lots of holes and many hours of patching.
Or you can run wiremold.
jbfan is online now   Reply With Quote
Old 05-05-2010, 09:47 PM   #4
Lightbulb
And some ceiling exhaust fan models come with lights, choice of; regular and nightlite!!
spark plug is offline   Reply With Quote
Old 05-06-2010, 02:50 PM   #5
Totally screwed together
The easiest way to do this would be to drop you ceiling down 2" with 2x4 sleepers and a new layer of drywall. This will allow you to place the fan electricals where you want to mount it, and the can lights too. Run everything with armored cable since it will be within 1.5" from the surface. All that would then get covered with new drywall.
xxPaulCPxx is offline   Reply With Quote
Old 05-06-2010, 06:04 PM   #6
I contest that this is the easiest way...
Although it would be the nicer way to do it.
Old 05-06-2010, 08:24 PM   #7
Well, easier than explainin to yer sig other what the heck you were doing running all that wiremold to the recessed lights!
Old 05-06-2010, 08:27 PM   #8
Stairguy
Millertyme's Avatar
Rewards Points: 508
that is a good idea paul. sound like that might be the most practical. what is wiremold?
Old 05-06-2010, 08:39 PM   #9
It is a surface mounted conduit system. It can be metal or plastic, and you can run power or low voltage (speaker) wire along walls and ceilings.
Great for quick and dirty, but ugly as all heck when exposed like on a ceiling. I used it awhile ago to run wire for lamps and surround speakers. I did it low so the furniture hid most of it.
Old 05-06-2010, 11:48 PM   #10
Here's a picture of a similar idea using Wiremold raceway with a surface-mount fan box.
Definitely not the prettiest, but when you can't or won't tear up the walls/ceilings it is one of your few options (aside from installing a shallow drop ceiling of course ).
Good luck.
Old 05-07-2010, 06:32 PM   #11
Household Handyman
Rewards Points: 1,408
What is above the area you are wanting to place the new ceiling fan--another room? IF you cut a 4 1/2" hole in your present ceiling, what would you find just above the ceiling drywall? You state you have electrical outlets in the room, so electricity is near. Not exactly a DIY job, but IF there is vacant space above your ceiling drywall, then electrical wiring supply for the fan can be ran to that spot. You may have to hire an electrician if you want it done this way. David
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Installing furnace in attic doingitmyself HVAC 0 09-08-2009 08:20 AM
Installing a ceiling fan k.kuenn Electrical 11 07-22-2008 02:44 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
