Installing A Ceiling Fan With A Light Switch. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2004, 12:08 PM   #1
Guest
Guest
Posts: n/a
Angry
Installing a ceiling fan with a light switch.
I have 4 wires coming out of my conduit - red, black, white and ground - and the instructions just call for the black, white and ground wire. If I just ignore the red wire it doesn't work.
Help would be GREATLY appreciated.
Robert
Old 02-05-2004, 09:11 PM   #2
Guest
Guest
Posts: n/a
One more thing....
There is a light switch for it but only one.
It turns off both the fan and the light if they are turned on.
Thanks again,
Rob
Old 02-06-2004, 02:57 AM   #3
Rob
If you purchase a remote control and receiver from one of your big box home centers it will make the use if your fan and light more useful and user friendly.
Ron in Southern Md. is offline   Reply With Quote
Old 02-06-2004, 10:19 AM   #4
Guest
Guest
Posts: n/a
Thanks Ron but this is for my back patio and the pull chains will work just fine.
Old 02-27-2006, 06:15 PM   #5
Theoretically you would hook the fan's black to the black, the fan's blue to the red, the fan's white to the white, and ground to ground.
Right now, you have it hooked up black and blue to black, white to white, and it works but only one switch controls it . . . yes?
Write back or check here for more information on ceiling fan wiring:
http://www.ceiling-fans-n-more.com/c...fan-wiring.php
ceilingfanrepair is offline   Reply With Quote
Old 08-22-2011, 02:26 PM   #6
I had the same problem!
I tried three times before I got it right. It's blue wire to red wire, and black wires together, and grounding (green or bare) wires together. More about that here meedandpea.blogspot.com
LDugan is offline   Reply With Quote
Old 08-22-2011, 04:55 PM   #7
Licensed electrician
Rewards Points: 1,474
I really hope the Op has solved this issue from 6 years ago.
Old 08-22-2011, 06:15 PM   #8
Electrical Contractor
kbsparky's Avatar
That was 7 years ago....
-KB
Old 08-22-2011, 06:39 PM   #9
Darn, how time flies.
Old 08-23-2011, 03:36 AM   #10
jackpercy57 is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
ceiling fan light switch replacemnet thomasr1950 Electrical 1 03-18-2006 02:42 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 08:10 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
