Old 03-26-2010, 11:15 AM   #1
installing ceiling fan/light fixture.
Have an existing basic light fixture (light bulb only) wired by basic black and white setup. What do I need to do to change out that light fixture and add a ceiling fan/light fixture.
raineydr is offline   Reply With Quote
Old 03-26-2010, 11:38 AM   #2
Master Electrician
The first thing to do is replace the existing j-box with a box or assembly rated to support a ceiling fan.
brric is offline   Reply With Quote
Old 03-26-2010, 11:41 AM   #3
the basement is not finished so after i do this am I down to just basic color coded wiring?
Old 03-26-2010, 11:45 AM   #4
Master Electrician
Yes. If you want separate switches for the fan and light replace the two wire cable going to the ceiling with a three wire cable and change the switch box to a two gang.
g
The Following User Says Thank You to brric For This Useful Post:
raineydr (03-26-2010)
Old 03-26-2010, 11:51 AM   #5
can i install a ceiling fan/light fixture and just use the pull string to turn off the lights and leave the fan running?
Old 03-26-2010, 12:11 PM   #6
Master Electrician
yes you can do that...it'll show you how to hook it up both ways in the instructions for the fan. you'll just have to manually turn the fan/light off if you want the other to stay on.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
Installing ceiling trim with uneven ceiling. capslock Carpentry 3 03-21-2010 12:53 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 09:40 AM
Ceiling Fan w/light fixture Unregistered Electrical 5 02-28-2006 02:06 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
