-   -   installing ceiling fan/light fixture. (http://www.diychatroom.com/f18/installing-ceiling-fan-light-fixture-67640/)
raineydr 03-26-2010 11:15 AM
Have an existing basic light fixture (light bulb only) wired by basic black and white setup. What do I need to do to change out that light fixture and add a ceiling fan/light fixture.
brric 03-26-2010 11:38 AM
The first thing to do is replace the existing j-box with a box or assembly rated to support a ceiling fan.
raineydr 03-26-2010 11:41 AM
the basement is not finished so after i do this am I down to just basic color coded wiring?
brric 03-26-2010 11:45 AM
Yes. If you want separate switches for the fan and light replace the two wire cable going to the ceiling with a three wire cable and change the switch box to a two gang.
g
raineydr 03-26-2010 11:51 AM
can i install a ceiling fan/light fixture and just use the pull string to turn off the lights and leave the fan running?
andrew79 03-26-2010 12:11 PM
yes you can do that...it'll show you how to hook it up both ways in the instructions for the fan. you'll just have to manually turn the fan/light off if you want the other to stay on.
