Installing A Ceiling Fan In A Drop Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2014, 08:51 PM   #1
From Philadelphia
Rewards Points: 275
Installing a ceiling fan in a drop ceiling
I am installing a ceiling fan on the second floor of a rental unit. The ceiling is currently a drop/suspended ceiling with 2x2 ceiling tiles. Above the tiles, there are no joists, just the roof rafters. Any tips on installing a ceiling fan in this situation?
hellohello is offline   Reply With Quote
Old 04-02-2014, 09:02 PM   #2
Rewards Points: 256
how high is the rafter above the ceiling joists? You can get install the fan base in the rafters and use a downrod through the drop ceiling.
JustinK is offline   Reply With Quote
Old 04-02-2014, 09:03 PM   #3
Licensed electrician
Rewards Points: 1,020
You are going to need a fan rated support made for drop ceilings.
Aifittings.com has one in their catalog.
Old 04-02-2014, 09:14 PM   #4
From Philadelphia
Rewards Points: 275
Great, thanks Jim. This looks like what I need: http://www.aifittings.com/catalog/fi...ctions/Q-6.pdf
I've never seen one at any of the big box stores, but do you think a local electric supply house would normally carry something like this in stock?
Old 04-02-2014, 10:55 PM   #5
An electrical supply house would be your best bet.
Old 04-03-2014, 09:56 PM   #6
Sparky
Rewards Points: 510
caddy 512hdfm35 (35lb fan/50 Fixture) or caddy 512hdfm70 (70lb fan /90 fixture) are also good options, i've used the 35's in the past.
Techy is offline   Reply With Quote
Faux Tin drop ceiling Master Brian Building & Construction 1 02-14-2014 05:26 AM
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 01:39 PM
Installing ceiling trim with uneven ceiling. capslock Carpentry 3 03-21-2010 12:53 AM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 07:31 PM
Installing can lights in a drop ceiling..... rwk0930 Remodeling 1 02-19-2008 01:59 PM
