-   -   Installing ceiling fan in double wide (http://www.diychatroom.com/f18/installing-ceiling-fan-double-wide-75165/)
JANKEL 07-01-2010 09:37 PM
Just moved into a 2002 double wide and am attempting to install ceiling fans in all of the bedrooms, Removed light fixture and found that box will only support 15 lbs and fan/light to be installed is 35 lbs. Purchased a fan brace with the intention of adding extra support. Problem is I cannot locate any ceiling rafters to attach brace to! Insulation in ceiling is blown-in kind so difficult, if not impossible, to look for rafters with mirror and flashlight. Ceilings are all slanted. Anyone know how to do this - or have any suggestions? Thanks/
kbsparky 07-02-2010 11:06 PM
Many mobile homes used "pop-in" type boxes for ceiling lights (quick and cheep).
You should be able to locate the joists for an expansion box by using a short piece of wire, or putting your arm thru the hole and feeling around. Just be aware that many mobile homes have rather small "joists" for ceiling support. :huh:
I just installed a paddle fan in a mobile home today after having to install some blocking on a nearby truss/rafter, and using some rather long screws, etc. :whistling2:
frenchelectrican 07-03-2010 01:01 AM
You should able find the joints they will be spaced either 16" or 24" on centre
But be aware they will not use the standard lumber size on roof joints more like webbed 2X3 the last time I did see it.
But the wall yeah most modern one will use the standard 2X6 studs.
Also with ceiling drywall it will be either 3/8 or half inch the most { they keep it light and cheap }
Merci.
Marc
