Installing A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2008, 12:03 PM   #1
Installing a ceiling fan
Would it be impossible, or very difficult to install a ceiling fan in a living room where there is no access above the living room due to a finished attic? Can it be done strictly from underneathe?
k.kuenn is offline   Reply With Quote
Old 07-16-2008, 12:14 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Yes. It will involve cutting into the ceiling and the walls to run the wire. Do you mean the attic has been turned into living space, or just finished out for storage?
Old 07-16-2008, 01:09 PM   #3
It has been finished for living space.
Old 07-16-2008, 05:25 PM   #4
Before you commit, make little inspection holes at critical points to see what you're up against.
It's just amazing, some of the things you find inside walls.
I recommend using flexible ductwork to vent to the outside so you can avoid obstacles, even though it has higher resistance to airflow.
The fan manu can provide distance/duct-diameter rules of thumb.
If it's up to code you may be able to vent to the nearest (return) duct.
Old 07-16-2008, 05:43 PM   #5
jbfan's Avatar
Rewards Points: 142
He wants to install a ceiling fan, not an exhaust fan. I highly doubt that you could ever connect an exhaust fan to a return duct!
Old 07-16-2008, 06:16 PM   #6
That's a gotcha, fair and square!
If this fan-like device is over 35 pounds (1999 NEC) it needs to be supported by other than just the electrical box. . .right?
Old 07-18-2008, 01:54 PM   #7
I have the same situation
I am also trying to install a Ceiling fan (in my living room) where there is not a receptacle and closed to overhead access... There is a recessed light operated by a switch about 5 ft away that I was thinking I could splice into, but I am hesitant and I don't want to break code.
Any one know for sure what the best way to do this is?
paul110h is offline   Reply With Quote
Old 07-18-2008, 01:56 PM   #8
P.S. Buffet Rules!
Old 07-19-2008, 07:00 AM   #9
Master Electrician
JohnJ0906's Avatar
Use a fan bar such as this : http://www.arlcatalog.com/Fan_Fixtur...nstruction.htm
Or find a floor joist close to the location that you want, and use something like this: http://www.arlcatalog.com/Fan_Fixtur...ng%20Boxes.htm
Cut the holes necessary to run a wire either to that recess can, if you want them controlled by the same switch, or to the switch location if you want to add a switch. Or, if you wish to use a remote control, you can run to the nearest receptacle, for a constantly hot wire.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-22-2008, 11:42 AM   #10
Thanks for the reply
The house was built in 2004 what wire (and were is the best place to get it)?
Old 07-22-2008, 11:47 AM   #11
jbfan's Avatar
Rewards Points: 142
What size is the breaker feeding the lights. It may be #14 and a 15 amp breaker, or it could be #12 and a 20 amp breaker.
HD, Lowes a hardware store.
You will have to drop the inside of the can to get to the junction box on the light, tie in your new wire to the fan and reinstall the light. It will be tight quarters.
Old 07-22-2008, 03:44 PM   #12
Thank you for the reply I am pretty sure its a 20 amp but I will verify. I am not too concerned about replacing the light cause the fan has a light on it Would it be o.k. just to cap it?
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 09:09 AM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
