Installing A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 02:46 PM   #1
I would like to install a ceiling fan over my dining room table. I have assembled many ceiling fans in the past so I know what is required. I have a plastic electrical box (not a metal fan rated one). There is no attic access so I can't replace the box. I was wondering if I could secure the fan to the wood stud beside the box and use the upper canopy ( shown in picture below) to cover everything.
I have seen this method discussed in a Home Depot "Wiring 123" book, so it's probably been carefully tested and safety ensured. What do you think?
Max c is offline   Reply With Quote
Old 03-02-2013, 02:51 PM   #2
Rewards Points: 6,652
You can using a Smart box, or one of these http://menards.com/main/electrical/r...195-c-6431.htm or these http://menards.com/main/electrical/r...196-c-6431.htm
Old 03-02-2013, 02:51 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If you dont want to move the existing hole and patch...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Max c (03-02-2013)
Old 03-02-2013, 02:53 PM   #4
E2 Electrician
Originally Posted by gregzoll View Post
Since when is a smart box fan rated?
never mind, just found one...
Max c (03-02-2013)
Old 03-02-2013, 03:04 PM   #5
Thanks for the reply! I was also wondering if it would be safe to mount the fan's bracket to the wood stud beside the electrical box.
Old 03-02-2013, 03:08 PM   #6
E2 Electrician
you need an electrical box regardless of any situation, but in a nutshell, fans either need to be supported by an electrical box that is FAN rated, or independently of the box but by the structure itself.... either or is acceptable... sounds like your BEST option is to remove the existing box, and replace it with a fan rated Smart Box...
Old 03-02-2013, 04:01 PM   #7
It takes a bit to find that one. http://www.smartboxinc.com/electrical_boxes.php#RND
Installing ceiling mount shower head to sloped ceiling wgburgess Plumbing 3 04-05-2012 07:47 AM
Installing a ceiling fan with existing 3.5" light fixture box? Superorb Electrical 14 04-03-2012 01:05 PM
Installing a new ceiling light scenario KUIPORNG Electrical 6 10-12-2011 01:35 PM
Installing a ceiling fan in a new construction home HEMMY1244 Electrical 4 09-15-2010 07:11 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
