Installing A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 05:28 PM   #1
Installing a ceiling fan
Okay so I was planning on installing a new ceiling fan in the master bedroom, which I started by taking off the old one, then I found a flat circle mounted on the ceiling with two bolts. I cant tell if its a pancake box or what? Because when I try to install the mounting bracket for the new fan the screws are too thick for the bracket. Now what to do ?
Thanks for the feedback
PS
I tried attaching a picture
sarms is offline   Reply With Quote
Old 08-06-2012, 03:43 PM   #2
I think what you see there was supposed to be attached to a proper junction box and instead got screwed directly to a stud. I would take that thing off and install a proper, fan supporting junction box.
freedomlives is offline   Reply With Quote
Old 08-06-2012, 03:49 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You need an electrical box regardless, whether it's fan rated or not depends on if you can mount the fan to the structure or not. You have a few choices depending on the actual joist location.
In your picture, looks like your best option would be to purchase a pancake fan rated box and secure the fan box to the joist itself, then the fan to the fan rated box. That is if there is actually a joist holding up the original fan.
Old 08-06-2012, 04:21 PM   #4
"So I Re-Wired It"
MisterZ's Avatar
Wow, are those wires just pulled thru the plaster? :o
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-06-2012, 04:23 PM   #5
E2 Electrician
Dont seem so surprised... it's pretty common.
The Following User Says Thank You to stickboy1375 For This Useful Post:
MisterZ (08-06-2012)
Installing ceiling mount shower head to sloped ceiling wgburgess Plumbing 3 04-05-2012 07:47 AM
Installing a ceiling fan with existing 3.5" light fixture box? Superorb Electrical 14 04-03-2012 01:05 PM
Installing a new ceiling light scenario KUIPORNG Electrical 6 10-12-2011 01:35 PM
Installing a ceiling fan in a new construction home HEMMY1244 Electrical 4 09-15-2010 07:11 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
