-   -   Installing a ceiling fan (http://www.diychatroom.com/f18/installing-ceiling-fan-149714/)
sarms 07-09-2012 05:28 PM
1 Attachment(s)
Okay so I was planning on installing a new ceiling fan in the master bedroom, which I started by taking off the old one, then I found a flat circle mounted on the ceiling with two bolts. I cant tell if its a pancake box or what? Because when I try to install the mounting bracket for the new fan the screws are too thick for the bracket. Now what to do ?
Thanks for the feedback
PS
I tried attaching a picture
freedomlives 08-06-2012 03:43 PM
I think what you see there was supposed to be attached to a proper junction box and instead got screwed directly to a stud. I would take that thing off and install a proper, fan supporting junction box.
stickboy1375 08-06-2012 03:49 PM
12 Attachment(s)
You need an electrical box regardless, whether it's fan rated or not depends on if you can mount the fan to the structure or not. You have a few choices depending on the actual joist location.
In your picture, looks like your best option would be to purchase a pancake fan rated box and secure the fan box to the joist itself, then the fan to the fan rated box. That is if there is actually a joist holding up the original fan. :)
http://www.foxelectricsupply.com/Con...uct/fsb405.jpg
MisterZ 08-06-2012 04:21 PM
Wow, are those wires just pulled thru the plaster? :o
stickboy1375 08-06-2012 04:23 PM
12 Attachment(s)
Dont seem so surprised... it's pretty common. :furious:
