Installing A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2007, 04:12 PM   #1
Installing a Ceiling fan
I installed a ceiling that is controlled by a remote. I connected all the wires that the directions indicated. I have a red wire that I do not know what to do with.
mweigand is offline   Reply With Quote
Old 12-30-2007, 04:21 PM   #2
Electrician philosopher
The red wire is most likely there to switch iether the fan or the light kit. Simply put a wirenut on it. I'm guessing you now have an extra wall switch, also.
Andy in ATL is offline   Reply With Quote
Old 12-30-2007, 05:28 PM   #3
member
leoacrh's Avatar
Post
are you talking about a red wire in the ceiling, or a red wire on the transmitter,if it's the the red wire from the transmitter then it should connect with black line from the ceiling,the black line from the transmitter connect with the black line from the ceiling fan
leoacrh is offline   Reply With Quote
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 08:09 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
installing a ceiling ladder jerry1967 Carpentry 6 11-20-2006 11:18 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 08:10 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
