Installing Cans And Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 12:08 PM   #1
Installing cans and fan
My mast. Bdrm has a light switch controlling an outlet (aaagh). I'd like to re-wire four cans and a ceiling fan. Do I need to worry about overloading the circuit? How can I tell if that will be a problem?
maxman10 is offline   Reply With Quote
Old 08-20-2012, 12:25 PM   #2
Rewards Points: 13,732
It's not going to be a problum.
Old 08-20-2012, 12:25 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
If you plan on using incandescents....then there is a chance it could be a problem....
You have to figure out how much is already on that ckt....
'Typically', lights are on a 15A ckt and outlets (recepticals) on a 20a ckt.
Is that switched outlet on a 15 or 20?
Of course, you have already gone through your house and made a map of every outlet and switch and which breaker it goes to....right? Of course you have, silly of me to ask...........(not ragging on you....just a friendly suggestion....it pays off later)
The ckt will be protected either way...but you don't want to exceed the limits of the switch either.
Figure out what all is aready on the ckt...figure out what the chances are that the other devices might be on at the same time and that will give you an idea of your breathing room on load.
One would assume that if the switch is controlling a 15a outlet...then you could potentially have a 15a load....
So....to answer your question after all the above mumbo jumbo....Yes, you 'should' be ok.....
Of course, the experts will chime in if I'm wrong.....
