Installing Can Lights Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2009, 07:55 PM   #1
Installing can lights question?
I want to put a can light between joists (basement ceiling) where my gas line for my fireplace upstairs runs. Its not in the way but just wondering if there is a code against it? the can light is a H7ICT by halo. It is rated for insulation, which I plan on installing too, for noise reduction. all response are welcomed of course! But would also like to here from some qualified electrians too!
luweee is offline   Reply With Quote
Old 02-14-2009, 08:02 PM   #2
Electrician
As long as the gas line isn't in the way and will not interfere with the correct installation of the light fixture, there are no restrictions in the code (NEC) for this situation.
However, I can't speak for any local amendments or fire codes, building codes, gas codes. I would find it hard to believe that there would be any restrictions in those as well, but a call to the local building inspections office couldn't hurt.
EBFD6 is offline   Reply With Quote
Old 02-14-2009, 10:29 PM   #3
Thanks EBFD
I think I will just go with that. I understand I should check local code. But if other areas allow it. I will go with it.
Installing pot lights billybarty Electrical 19 03-18-2008 06:58 PM
Installing can lights in a drop ceiling..... rwk0930 Remodeling 1 02-19-2008 12:59 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
4-gang box question diverdaveman Electrical 3 09-11-2007 09:00 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
