Installing Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 02:43 PM   #1
installing can lights
I want to install 4 can lights into my modular home. is this possible?
L David is offline   Reply With Quote
Old 04-12-2012, 03:46 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
It is always possible depending on how much wall or ceiling damage you are willing to repair.
More details needed. Is there accessible space above the ceiling? Describe what you mean by a modular home (some people would say a double wide is a modular home). Do you have access to a crawl space or basement?
If you plan to do this yourself, what is you level of competency and do you have tools? Have you done this type of electrical work before? Does your locality allow homeowners to do electrical work? Are you prepared to obtain a permit and follow an inspection schedule?
Coastal South Carolina
Old 04-12-2012, 03:51 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Modular home? Almost certainly yes.
Mobile home? Almost certainly no, or not worth it.
Old 04-13-2012, 04:17 PM   #4
Licensed electrician
Rewards Points: 1,872
Manufactured homes, AKA trailers typically do not have enough depth in the ceiling framing to allow the housings to fit.
A modular would be no different than a stick built house as far as adding the recessed.
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 10:30 AM
Installing to motion sensor lights KENNEDYCHIEFS34 Electrical 1 08-22-2011 07:50 AM
installing recessed lights, entertainment center overload? fabian Electrical 5 01-13-2010 12:25 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Installing Recessed Lights IdahoBob Electrical 6 08-23-2007 10:03 PM
