Installing A Breaker "backwards" - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 08:38 AM   #1
Installing a breaker "backwards"
Well, not jamming it into the box backwards, but using it "backwards". Is this possible?? Here's what I mean:
I'd like to use a shed sub-panel as a loadcentre. Right now, I am feeding a Siemens sub-panel from the house to the shed - 20A, single phase. OK - I didn't do that part. that was the former owner. It's a nice panel though - appears new almost - and I want to upgrade to 30 A two phase to handle splits for power tools, lights, and a small, tankless water heater.
The idea:
  • run 8/3 off a 30A breaker in the house to the shed (roughly 25 metres away). I believe 8/3 is overkill.
  • connect the LINE from the house into the LOAD side of another 30A in this sub-panel
  • Have the sub-panel 30A breaker act as the panel disconnect
Sounds simple enough, and I am a very simple person I have been told. Can breakers work in this configuration tthe way they are intended to? Is it still the same protection? And, what would the neutrals + grounds need to look like in this situation (and why?). I am thinking that I should have a ground rod or plate at the shed.
Do-able or dumb?
Thanks for the truth.
jcliffo is offline   Reply With Quote
Old 11-16-2009, 08:43 AM   #2
You can back feed a panel by inserting a breaker in place
BUT the panel MUST be rated to handle the power
Does this panel have a main breaker, what is the breaker size ?
IE you can't back feed a 60a rated panel with 100a
Old 11-16-2009, 08:59 AM   #3
Thanks.
If I follow you, this practice would appear to be do-able provided (i) I don't ask for too much from the house, and (ii) drive it into too small a panel in the shed.
  • The house main disconnect is 200A which I didn't do but it looks typical to me.
  • The big draws on that panel are AC, RANGE and DRYER. The usual suspects follow after that, a variety of lights and plugs, with the washing machine, microwave, dishwasher, shed, a panel plug (GFCI), and fire alarms being on distinct breakers. There are a couple of kitchen splits in there, too.
  • Looks to be around 10 years old and everything matches.
  • The sub-panel in the shed is rated at 100A.
I hope that helps you answer me.
Is there any special consideration I should give to Neutral and Ground in this application?
Thanks again.
PS By the way, I think I goofed when I said I wanted to ugrade to "two phase". Sorry - I'm using the language all wrong. What I meant - which you probably recognized - was to merely upgrade from a 120V to a 240 V service.
Old 11-16-2009, 10:32 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
You also need a breaker hold down kit to hold the backfed breaker in place!
jbfan is online now   Reply With Quote
Old 11-16-2009, 10:38 AM   #5
Does the sub-panel have a main breaker?
If so then you don't need another breaker IF you are feeding it from the house with a 30a 240v breaker
I have a 100a main breaker panel in my pool cabana fed with a 60a in the house
As long as the 100 panel lugs are rated to take #8 wire or #6
You might want to think about 6-3 & install a 50a or 60a breaker in the house
Seems you have plenty of power in the house with a 200a panel
If the garage is detached (seems like it?) then you also need (2) grounding rods at the garage
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Installing breaker panel...need info DVLCHLD Electrical 6 09-18-2008 09:54 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Installing a 220volt circuit breaker. luweee Electrical 16 01-11-2008 07:59 AM
