-   -   installing a bathroom heater (Step1) (http://www.diychatroom.com/f18/installing-bathroom-heater-step1-53510/)
pstock 09-21-2009 03:23 PM
at the risk of ridicule, let me ask a few questions about installing a basic bathroom heater.
1. is it insane for a non-electrician to do anything with 220v-240v power? I mean, I don't mind learning a few shocking lessons on 110v but can't 220/40v kill you?
For instance (and I think I am probably answering my own question) before I ask about hooking this thing up,
can I use a regular multimeter to test the presence of current on the line before I start hooking things up?
120v, no problem. I set the thing to 200v, stick the black and red in the slot and presto, it shows me 118v.
but I am really nervous doing the same thing with a 240v circuit.
thoughts?
Peter
Code05 09-21-2009 03:36 PM
thoughts?
Peter
Installing 240 is really no more dangerous than 120, if done safely. what kind of meter do you have. Does it say CAT III anywhere on it?
jbfan 09-21-2009 05:05 PM
120 volts kill you just as dead as 240 volts.
Just make sure the breaker is off, and you run the correct wire for the heaters.
