Installing Bathroom Fan/light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 04:18 PM   #1
Installing bathroom fan/light
I'm replacing a 20 year old bathroom fan/light that connects to a single on/off switch. The current wiring in place is black, white, red and a ground. I recently bought the Nutone QTN110LE fan/light. The wiring is quite different. The new fan offers various options (just light, just fan, nightlight etc) but that all works with a multi-control switch which I'm not interested in. I just want to turn it off and on and don't need the nightlight option. The new unit wiring is 3 whites, and one red, black,blue and green. What do I hook up to my current wiring and what do I do with the wires that won't be used? Here are the specs/diagrams http://bit.ly/XaeE5t. Thanks!
sodowarts is offline   Reply With Quote
Old 10-14-2012, 05:02 PM   #2
Oso954's Avatar
Rewards Points: 1,098
You linked to the architectural spec sheet, not the installation instructions.
http://www.homedepot.com/catalog/pdf...ruik|202518603
The red is the night light. If you can identify the white that is associated with it, you could coil them back. Connect the blue (light) and the black (fan) to your romex black. Connect the remaining two whites to your romex white.
If you cannot ID the night light white, or simply want the easy way, connect the red, blue, and black from the fan to your romex black, and the 3 whites to your romex white.
Then you can decide whether to install the night light bulb or not.
Oso954 is online now   Reply With Quote
Old 10-14-2012, 05:28 PM   #3
Thank you Oso! Each of the the whites are taped with another color (one red, one blue and the other taped with the black wire). So that helps. So will I be using the red wire that currently runs from the switch (in addition to the black and white)? Assuming the green wire is the ground?
Old 10-20-2012, 12:48 PM   #4
What do I do with the romex red??
Old 10-20-2012, 02:14 PM   #5
Rewards Points: 6,652
If you have two switches, one for the fan, one for the light, the Red & Black would associate with the switch at the wall.
Old 10-21-2012, 12:00 PM   #6
Installing similar bath fan
I am installing a bath fan similar to the one above but with a couple different issues. I'm hoping you can assist me also. Wiring from the fan is the same. Red and white are for the nightlight, blue and white are for the light and black, green and white are for the fan. I have a black, red, white and green installed in the ceiling. These wires are fed from the two switches that fed the previous fan. One switch(black, black and ground) ran the fan and another switch (black, red and ground) fed the light.
How can I set this up so I can run the light, nightlight and fan independently. I purchased a two way rocker switch in hopes of running the light and nightlight on the switch that previously just ran the light.
Thank you in advance.
Ajaxelcinrab is offline   Reply With Quote
installing odd bathroom light austinbblock Electrical 16 10-10-2012 06:47 AM
Installing a plumbing vent on a basement bathroom Breadmaker Plumbing 4 09-21-2012 08:18 PM
Installing shower membrane worth re-doing bathroom? david9012 Plumbing 6 01-08-2012 09:02 PM
installing a bathroom heater (Step1) pstock Electrical 2 09-21-2009 04:05 PM
Bathroom Fan/Light will_53115 Electrical 3 09-12-2008 02:24 PM
