Installing Basement Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 09:16 AM   #1
Installing basement recessed lighting
Finishing basement and have a few questions...
1. Have already bought recessed cans. Commercial Electric brand. I have now read a few places that these are junk. Why exactly and should I return them? Need to know know before I paint them black.
2. I plan on installing 12 lights on new 15A circuit using 2 switches one for left side of basement one for right (6 x 6). This is OK yes? Both switches will be in same box. And will be only thing on this new circuit.
3. Assuming I am running hot lead from main panel to switch box...there is no fancy wiring that needs to be done correct? 14/2 black to black, white to white except at switch correct?
jdtox is offline   Reply With Quote
Old 05-02-2012, 03:19 PM   #2
Master Electrician
wiring sounds good. Wondering why your going to paint the cans though. The amount of heat generated will likely just melt it and make your basement stink or start a fire. Probably not a great idea.
andrew79 is offline   Reply With Quote
Old 05-02-2012, 03:51 PM   #3
Licensed electrician
Rewards Points: 1,598
The black will absorb a lot of the light given off by the bulb and result in a darker than planned area.
Old 05-02-2012, 04:14 PM   #4
Just use a black baffle trim. I would NOT paint the cans
Evstarr is offline   Reply With Quote
Old 05-02-2012, 05:39 PM   #5
Black baffle trims make a light colored ceiling look like swiss cheese.
Old 05-02-2012, 06:25 PM   #6
I am painting the outside of the cans black because the basement ceiling is going to be painted black. I don't want shiny metal cans to stick out like a sore thumb in an otherwise black ceiling.
Old 05-02-2012, 06:32 PM   #7
Isn't that what the recessed part of recessed lighting is supposed to address? :confused
Old 05-03-2012, 07:47 AM   #8
Ok my basement has only joists above, there will be no ceiling tiles installed and no drywall. I am leaving the ceiling "as is" however I will be spraying it flat black. Including all ductwork, pipes, wires, etc. I'm sure you have seen this at your local bar or pub.
I have seen this done before in basements and it looks fantastic, plus I will not have to lower my ceiling and I will still have access to everything.
Yes the lights will be up in between the rafters, but I don't want to see that bare metal look at all. If lights are installed they will get the black treatment anyways, so I figure I spray them first. I bought Heat Resistant BBQ paint in flat black to match.
Old 05-03-2012, 05:13 PM   #9
Rewards Points: 370
can we get a picture when you're done? be interested to see how it looks.
Also, if it is all exposed the wiring isn't allowed to be NM wire, so there is something "fancy" that needs to be done. (I believe metal wrapped electrical wire is good, I forget the technical term and someone far more knowledgeable than I will be along to give you the deep technical answer shortly)
MLMIB is offline   Reply With Quote
Old 05-03-2012, 05:21 PM   #10
Can you cite the code requirement?
This is from Article 334. There are also more sections that apply.
(A) Type NM. Type NM cable shall be permitted as follows:
(1) For both exposed and concealed work in normally dry
locations except as prohibited in 334.10(3)
Old 05-03-2012, 05:53 PM   #11
Rewards Points: 370
I thought basements were usually considered damp? I could be wrong, certainly open to that too.
Old 05-03-2012, 08:19 PM   #12
Originally Posted by jdtox
Ok my basement has only joists above, there will be no ceiling tiles installed and no drywall...
...I'm sure you have seen this at your local bar or pub...
...up in between the rafters .... I bought Heat Resistant BBQ paint in flat black to match.
Ahh!!! Now I get it!
Probably have not seen too many recessed cans at the pub like that. They seem to prefer track heads.
Not that I often remember nights in the pub. I mean not that I often go to the pub. Lol
The BBQ paint should hold but clean the cans off well. Halo and Juno back in the day used to ship the darn things with a light oily coating on them.
Maybe don't paint the thermal cutout switches on them if external.
Old 05-03-2012, 08:35 PM   #13
Master Electrician
ahh i get it now too, cool idea and good call on the bbq paint. I'd be interested to see the finished product as well. And on a side note it still allows you ceiling access for the future
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
Old 05-06-2012, 09:44 AM   #14
Why not just install a metal j type box and spend the extra money on the new LED lights. I just installed them in a new kitchen and you don't need a whole recessed housing. Also led's don't pull hardly any current and don't get hot. Just a tip. Good luck
johnzenobia is offline   Reply With Quote
Installing recessed lighting Pat Mendo Electrical 1 03-23-2012 06:39 AM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 08:43 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 11:53 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
