Installing Baseboardheaters - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 08:59 PM   #1
Installing baseboardheaters
I would like to install two six foot 1500 watt heaters in a new room addition, I have run 10/2 with ground can I run them on 120? If so can they be on the same circuit in paralell with a thermostat. If so can I use a single 30 ampe breaker for this.
fylopad is offline   Reply With Quote
Old 03-03-2009, 09:07 PM   #2
Check the box or instructions,you need to find out if they are rated at 120 volts or 240 volts. Probably 240.
Plumbvoltage is offline   Reply With Quote
Old 03-04-2009, 04:46 PM   #3
Electrician
Rewards Points: 802
Chances are these will be 240V heaters, and putting that on a 30A breaker with 10/2 would be acceptiable.
Depending where you live will decide if these can be run from 120 on a 30A breaker. In Canada this would not be allowed but the NEC is dierrent then our codes/
darren is offline   Reply With Quote
Installing plinth blocks? Badfish740 Carpentry 6 02-09-2009 10:45 AM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 03:10 PM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
Installing dryer outlet in laundry room ManMythLegend Electrical 11 07-13-2008 10:36 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
