Old 11-22-2010, 08:05 PM   #1
installing an air compresser
the air compressor i want to get is 240 volts at 15 amps. right now i have only 115 volts in the garage. My house only has a 100 amp service. So should i have vepco dropin a new box or what should i do. thanks
demarco tim is offline   Reply With Quote
Old 11-22-2010, 08:35 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Is this garage is attached or detached ??
Do you have any spare room in your breaker box ??
once you answer two question then we can able help you the correct way to do this.
Merci.
Marc
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 Electrical 18 10-03-2009 11:20 PM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
