Installing An Additional Outlet In A Laundry Room - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 10:43 AM   #1
Installing an additional outlet in a laundry room
I have an old unitized washer/dryer in a laundry room closet that i'm replacing with new front loading, stackable machines. when the installers came, they said they couldn't install them because the old machine (one unit) used just one plug, the existing 240v dryer outlet. to install the stacking units, they would need an additional 120v laundry room outlet for the washer. an electrician i consulted with said he would need to cut through dry wall and run a new wire/outlet from my electrical panel across the house. can't he just split off from the existing 240v outlet in the laundry room to wire an additional 120v outlet?
Condoowner is offline   Reply With Quote
Old 09-22-2011, 10:50 AM   #2
Code05's Avatar
Rewards Points: 1,104
No, the existing receptacle is most likely on a 30 amp breaker and you cannot tap that for a 15 or 20 amp one. You might also have only a 3 wire cable with no neutral.
Code05 is offline   Reply With Quote
Installing 230V Outlet - Chicago - Code OakBehringer Electrical 5 07-13-2011 08:29 PM
Securing Electrical Outlet in Unfinished Room - Cement smohamed9 Electrical 2 04-04-2010 09:53 AM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
Building an additional room lmc Building & Construction 2 09-13-2006 04:27 AM
